Old 07-21-2021, 07:10 PM   #1
std1940
std1940's Avatar
Default 3" Shock Links 1940 Coupe
Who has the best quaiity 3" shock links for a 1940 Coupe?
std1940 is offline   Reply With Quote
Old 07-21-2021, 07:24 PM   #2
Fred A
Fred A's Avatar
Default Re: 3" Shock Links 1940 Coupe
I had trouble with 3" links on the front. I needed 4" to make the connection. Good Luck: Fred A
Fred A is offline   Reply With Quote
Old 07-21-2021, 07:30 PM   #3
Kube
Kube's Avatar
Attempt to locate NOS. They're around. The repops are "okay" at best.
3" on the rear of ALL '40 Ford passenger cars.
3" on the front if the car is NOT equipped with a factory sway bar.
4" on the front of all models when equipped with a factory sway bar.
Old 07-21-2021, 08:23 PM   #4
L78CHEVELLE
L78CHEVELLE's Avatar
Two NOS 3 inch links on eBay now. eBay item number:334084113007
L78CHEVELLE is offline   Reply With Quote
Old 07-21-2021, 08:32 PM   #5
Zeke3
Zeke3's Avatar
Contact Fred (barnfind08 on the Barn) at Southside Obsolete or Michael at Third Gen Automotive.
Zeke3 is offline   Reply With Quote
Old 07-21-2021, 08:53 PM   #6
Kube
Kube's Avatar
Those are NOT NOS. They are reproduction.
Old 07-21-2021, 08:54 PM   #7
Kube
Kube's Avatar
Great advice. 3" links are easy to find. 4" not so much.
Don't let anyone tell you other sizes than what I'd advised in post #3 are correct.
Currently on eBay (item 284371784375) is a set of NOS 4" links for $55. If I were you, I'd grab them and quickly at that. Note these are service replacement parts and while NOS, they are not concourse correct. However, they are GREAT quality and to the untrained eye, "just right".
There is a pair of 3" on eBay (item 273840620043) for $40. Fair enough.
Old 07-23-2021, 09:45 AM   #8
std1940
std1940's Avatar
I have found 4 what to be NOS Ford Script 3" shock links.
They appear to be very stiff.
How stiff should they be?
Is there a way the can be lubricated?
What would you use to lubricate them that would not damage the rubber seals?
Thanks for any help. Tom.
Old 07-23-2021, 10:04 AM   #9
Kube
Kube's Avatar
Stiff is good. NO lubrication.
If you have a sway bar on your Ford V8, you must use 4" links... don't forget.
Old 07-23-2021, 10:27 AM   #10
std1940
std1940's Avatar
Mike,
These actually came from you.
I just found them in my stash in a box from you dated 2013.
Thanks Tom.
Old 07-23-2021, 11:04 AM   #11
Kube
Kube's Avatar
Mike,
Thanks Tom.
Hilarious! I was just a kid then (I wish).
