06-27-2021, 09:00 AM | #1 |
growling noise
Good morning. My 29 Tudor has been making a growling sound when foot off gas when coming to a stop. If I disengage the clutch the noise stops. This has been getting worse. All fluids have been checked and all is good. Also greased the u-joint. Thanks, Bob
06-27-2021, 09:50 AM | #2 |
Re: growling noise
How about Throw out bearing/slider or pilot bearing? Remove cover and have a look! Just have to loosen two screws slide cover up/off.
www.whidbeymodelaclub.com Last edited by Gary WA; 06-27-2021 at 09:59 AM. |
06-27-2021, 10:35 AM | #3 |
Re: growling noise
I haven't checked that because it sounds like it is coming from the rear of car. When I check throw out bearing what should I be looking for?
06-27-2021, 10:43 AM | #4 |
Re: growling noise
If you think it is coming from the differential, drain the oil into a glass or clear plastic container and look for metal particles. Try putting a magnet in the oil to see if you can find any steel bits. If so then you will have to repair the differential.
06-27-2021, 11:49 AM | #5 |
Re: growling noise
Have someone stand outside our car and see if you can verify noise location. I think you need to. verify location and if the rear end quit driving and repair before more damage is done.
06-27-2021, 12:12 PM | #6 |
Re: growling noise
www.whidbeymodelaclub.com |
06-27-2021, 02:00 PM | #7 |
Re: growling noise
OK, what does disengage mean ?
When pushing on the clutch pedal if it makes the noise and then the noise stops when taking your foot off the clutch then its the sign of a bad release/throw out bearing. [ that is if there is enough lash/free play] Does the vehicle need to be moving for the noise, or, can it make noise sitting still ? If its coming from the rear does it make more noise either under power or when off the power ? |
06-27-2021, 02:30 PM | #8 |
Re: growling noise
Thanks for the help, Will check rear dif.and throw-bearing. Also the noise stops when i push clutch in when slowing down for a stop.
06-27-2021, 02:57 PM | #9 |
Re: growling noise
Bob has stated that the noise happens when slowing down for a stop and the noise stops when pushing in the clutch and still slowing down. So it would seem that it is not the throwout bearing but could be coming from the pinion and ring gear in the rear end or from the transmission.
So, does it happen in all gears or only a certain gear? To check the transmission it is easy to take the shift tower off and peek inside. Bob can drain the oil in the transmission and check for metal particles like for the differential. One thing to do would be jack up one rear wheel, but the car in neutral, and turn the wheel in the forward and reverse direction to try and feel for rough ring and pinion gears.
06-27-2021, 03:13 PM | #10 |
Re: growling noise
I know for sure always happens in second and third, not sure about first. I now have some direction on what to check. Thanks,Bob
07-01-2021, 07:27 AM | #11 |
Re: growling noise
Here is what I have done so far. Checked throw out bearing and that looked OK. Changed transmission fluid, no metal pieces. Drained fluid from differential, and checked with magnet no metal. Jacked up pass. side wheel turned freely in both directions with no problem. Drivers side turned but about 1/3 of the wheel had more resistance than the rest although it didn't seem too bad. Anything else to check? Thanks again.
07-01-2021, 07:58 AM | #12 |
Re: growling noise
Sounds like it to be the throw out bearing. Looking at it will not tell you if it is bad. See
if it will move (Wobble) side to side. If it does, it is bad. The slightest movement side to side with engine running and clutch depress will make a noise.
IN GOD WE TRUST - SEMPER FIDELIS John |
07-01-2021, 09:18 AM | #13 | |
Re: growling noise
07-01-2021, 09:18 AM | #14 |
Re: growling noise
Bob,
Driveline noise can be a little tricky at times…. But it sounds like your trans throwout is probably ok. They are noisy when clutch depressed. Not out. There’s a host of possibilities but one more common from the rear axle is loose or failing pinion bearings. The noise can get more noticeable when off the gas in 3rd like going down a hill. Driveshaft/pinion noise travels up the torque tube and can sometimes be confusing. If it can be jacked up securely on Jack’s stands and ran in gear with a good ear below in the driveline it may be able to be detected. Drivelines are my specialty and it’s just a matter of a good ear and detecting things. It’s very possible a rear axle rebuild may be in the future. The transmission should be quiet in 3rd if the bearings are good as it’s direct drive at that point. If noisy in 1st or 2nd only it would probably be more of a trans issue with those gears. They are usually noisier under load as it is the thrust side of the gears. Disengaging the clutch takes the load off the gears and can quiet them as you indicated. It also takes the thrust off things through to the driveshaft. Larry Shepard |
07-02-2021, 10:17 AM | #15 |
Re: growling noise
Thanks for every ones help. I agree with Larry that driveline noises are a little tricky to isolate the noise. I'm going to put it one jack stands this weekend and try to hear anything. Also went for a short drive and the noise is louder when letting off gas in third and going down hill. It looks like a major repair. I think I will take it well respected Model A repair shop here (50miles down the road) and get his opinion. Respect
