05-01-2021, 10:43 AM | #1 |
39 Pickup ??? Pars ID help please
I think these three pieces are all '39 pickup stuff. Yes? No? If so (or if not) can anyone ID year and what part they are?
The windshield frame measures 32" x 10 1/4" OVERALL. Thanks much, in advance.
"I can explain it for you. However, I can't understand it for you". Last edited by Kube; 05-01-2021 at 10:49 AM. |
05-01-2021, 11:02 AM | #2 |
Re: 39 Pickup ??? Pars ID help please
The skinnier part with the larger hole in the middle is a '39 (only) pickup dash. The wider part (goes above the windshield) and the back window frame are '38/'39 pickup. Don't know if those two fit any other years.
05-01-2021, 06:56 PM | #3 |
Thanks so much 1939MARS. I'm obliged to you.
05-03-2021, 09:53 PM | #4 |
Difference between the 38 and 39 as far as the "dash" is, where the front window crank is located. A "t" bar/hole being horizontal out the front of the dash, is 38 (towards you). 39 had a wheel/knob out the top of the dash. (vertically). The rest is universal 38/39, windshield frame to 41.
But you knew this already Mike. You probably have the original drawings! Last edited by Tinker; 05-05-2021 at 10:26 PM. |
05-04-2021, 08:03 AM | #5 | |
05-04-2021, 08:41 AM | #6 |
05-05-2021, 10:25 PM | #7 | |
Well, I don't know much. But I know a little bit about the 38-39 ford trucks. Even if I'm not very good at explaining it clearly and eloquently. 39 didn't have an ashtray in the dash front. 38 did. Oh course there could always be some overlap I guess. Last edited by Tinker; 05-05-2021 at 10:33 PM. |
05-05-2021, 10:56 PM | #8 |
The header panel above the windshield that covers the wiper motor and windshield hinges is the same '37-'39. As others have noted, due to the difference in the windshield regulator, the upper dash panel that covers the regulator is '39 only. Rear window garnish is the same '35-'39. I have a '38 that I've owned since 1966.
05-05-2021, 10:59 PM | #9 |
Lamar I've referred to your posts for years. Always learn and refresh my memory. Shot out the windows of my 38t, when it was a junked out truck in the barn, with a bb gun when I was 6. 40yrs later I had to replace them. They were de-laminated anyway. Or that's my excuse for doing that as a 6yr old.
05-06-2021, 02:17 PM | #10 |
Mike, Are you working on a truck?
05-06-2021, 02:42 PM | #11 |
No sir. Just attempting to sell off some parts I'd gathered over the past years (decades).
05-08-2021, 07:13 AM | #12 |
I do not think the header panels for pickups are the same from 37-39, with the 37 having two fairly large wiper motor covers not present on the 38 and 39. The 37-39 may have the same overall dimensions.
05-08-2021, 09:30 AM | #13 |
Could be the panel on top of the dash that fits '37-'38. They sure look the same to me. The'39 uses the different window crank location.
05-18-2021, 03:55 PM | #14 |
It seems that I was not 100% correct about the piece above the windshield being for both '38 and '39, but I do not know what the difference between the two is. I was just looking at the 1939 Body Parts List (pic attached) and found that the part for '39 has a 91C part #, implying there was an 81C part number as well. They will still interchange fit-wise, but does anyone out there know the difference?
