Old 07-06-2020, 07:41 AM   #1
Steves46
Steves46's Avatar
Default Ford Script Distributor Body
I found a Ford script Distributor Body stashed away from the previous owner. Since I thought it was really cool, I replaced my non-script Distributor and fired-up the car. Although is started-up, it acted like it had no power, even when I moved the throttle a bit and advanced the spark. Removed and repaced with the non-script and all was good. For the sake of learning, what would cause this? A possible crack inside the Bakelight that I couldn't see? I did not see any visable cracks or any other indicators. I would have really liked to use the Ford script Distributor Body but I guess it will sit on a shelf as a display piece.
If it aint broke, don't fix it!
Steves46 is offline   Reply With Quote
Old 07-06-2020, 07:44 AM   #2
chrs1961815
chrs1961815's Avatar
Default Re: Ford Script Distributor Body
Does it have one or two notches for the locating pin? Originals had only one. Might be a crack or short inside the contacts under the bakelite - if there are no visible cracks, it is probably that.
"The more things change, the more they stay the same."
chrs1961815 is offline   Reply With Quote
Old 07-06-2020, 08:17 AM   #3
Steves46
Steves46's Avatar
This one has 2 notches so it looks like this is not an original. Thanks.
Old 07-06-2020, 08:25 AM   #4
jb-ob
Steve,
Easy enough to check the clearance between the rotor tip & contacts in the body, .025 - .035.
jb
jb-ob is offline   Reply With Quote
Old 07-06-2020, 08:38 AM   #5
Steves46
Steves46's Avatar
I will do that-thanks. Learning something new everyday.
Old 07-06-2020, 11:42 AM   #6
katy
katy's Avatar
Beg, borrow or otherwise obtain a megger (https://en.wikipedia.org/wiki/Megohmmeter) and check between the terminals of the suspect body.
Old 07-06-2020, 11:55 AM   #7
Steves46
Steves46's Avatar
I have my trusty feeler gauge and will check this evening. Hopefully this will give me a good indication as to possible cause. Would really like to use the Ford script body. We will see...
Old 07-06-2020, 04:59 PM   #8
Steves46
Steves46's Avatar
Update....the rotor gap was within recommended specs and it made no difference so I will stick with my non script distributor body. Appreciate all the help.
Old 07-06-2020, 07:38 PM   #9
shew01
shew01's Avatar
Did you try setting the timing on the Script distributor? Or, did you just drop it into the head?
shew01 is offline   Reply With Quote
Old 07-06-2020, 08:48 PM   #10
chrs1961815
He is talking about the bakelite body that goes on top of the distributor, not the distributor itself. Timing stays the same.
Old 07-06-2020, 09:16 PM   #11
shew01
shew01's Avatar
Oops! I missed that.
Old 07-06-2020, 09:28 PM   #12
1930 coupe
Wash it with soap and water in the sink, a toothbrush works good.
Dried antifreeze and other chemicals that have dried on it can sometimes cause current paths, may or may not do any good, but won't hurt anything to try it.
1930 coupe is offline   Reply With Quote
Old 07-06-2020, 09:44 PM   #13
larrys40
Steve
The 2 pin notch was universal to be used on b as well. You will notice if you look at the slot opening there is probably a step. It should be filed down to work on an A otherwise it will force the upper plate arm down. I believe this is in the service bulletins in later time .
I favor these when I can find them.
Larry shepard
larrys40 is offline   Reply With Quote
Old 07-07-2020, 07:15 AM   #14
Steves46
Steves46's Avatar
Thanks Larry. I will take a look and see if there is a step.
Old 07-07-2020, 11:42 AM   #15
Steves46
Steves46's Avatar
Larry was correct-there was a step. Filed-it down and installed however there was no improvement and behaved the same as before; even with the spark advanced, the RPMs did not increase and when I fully retarted it, the motor stopped running. Since this was in the previous owner's parts stash, I suspect he already knew it was not going to work. Oh well, I'll keep my eyes out for another one reasonably priced.
Old 07-07-2020, 06:13 PM   #16
Ernie Vitucci
Good afternoon...I think that you have discovered why it was on the shelf and not on the car! They did sometimes tend to internal shorts...Ernie in Arizona
Ernie Vitucci is offline   Reply With Quote
Old 07-07-2020, 08:13 PM   #17
Steves46
Steves46's Avatar
Yes sir!
Old 07-07-2020, 08:52 PM   #18
Conaway2
Conaway2's Avatar
I’ve started hanging paper tags on spare parts I have to describe their condition....anticipating the next owner after me !.....
Conaway2 is offline   Reply With Quote
Old 07-08-2020, 12:07 AM   #19
norcalal
As with all parts that have an obvious defect not evident on first inspection, I toss them into the trash, rather than trying to get any money for something I know won’t work properly, and causing another the disappointment of finding that out for himself perhaps the hard way.
norcalal is offline   Reply With Quote
