Old 01-20-2019, 12:20 PM   #1
Steves46
Steves46's Avatar
Default Temp Probe Pipe Leak
It appears I have a pin hole leak around the welded area of my stainless temperature probe pipe on the top radiator hose. If I was to apply some JB weld or JB water weld around the area do you think that would seal the leak or would I be better off removing and taking it to a friend who can weld?
If it aint broke, don't fix it!
Steves46 is offline   Reply With Quote
Old 01-20-2019, 12:38 PM   #2
Purdy Swoft
Purdy Swoft's Avatar
Default Re: Temp Probe Pipe Leak
send it back !!!
Old 01-20-2019, 12:47 PM   #3
Steves46
Steves46's Avatar
That is certainly an option but would like to see if there is a quick and lasting fix.
Old 01-20-2019, 12:56 PM   #4
Purdy Swoft
I would think that solder , JB weld or a good stop leak would stop the leak . The thing is if it started leaking again later , you would probably wish that you had sent it back for a replacement . I have had good luck with the probe pipes that I have used
Old 01-20-2019, 12:56 PM   #5
katy
katy's Avatar
Ask the supplier to send you a replacement and then you send the defective one back.
Old 01-20-2019, 01:35 PM   #6
Charlie Stephens
If the part is new (just installed) SEND IT BACK. If the supplier won't take it back, give us their name. The only way the suppliers will stop selling low quality parts is if enough people return them. The problem is not with the manufacturers in foreign countries. The problem is with the suppliers in this country failing to provide adequate specifications and inspection and then rejecting the parts that don't meet the specifications. The parts will cost more but it will be less expensive in the long run to not have to deal with poorly made parts. How about a picture?
Charlie Stephens
Old 01-20-2019, 01:51 PM   #7
Steves46
Steves46's Avatar
It is new so I will be calling the vendor Mikes A-Fordable for an exchange. They are nice folks to deal with and I don’t anticipate any issues.
Old 01-20-2019, 02:02 PM   #8
DHZIEMAN
Mikes Affordable is great at responding to communications over faulty parts. Bought a 6 volt sealed beam, had one bad filament, new headlamp showed up a week later after I contacted them! Threw the old one away. I go to them first on any Model A stuff!
DHZIEMAN is offline   Reply With Quote
Old 01-20-2019, 03:22 PM   #9
Steves46
Steves46's Avatar
Yes-hopefully I will have a replacement in less than a week. I was disapointed for I had the radiator out for repair and finally had time to get everything buttoned-up only to have this silly leak. Oh well-better to discover it in my garage vice on the road. I attached a couple of photos. It appears not to have a very good bead on the inside of the pipe around the boss.
Old 01-20-2019, 03:37 PM   #10
The Master Cylinder
The Master Cylinder's Avatar
Pretty sloppy weld on the outside too.
The Master Cylinder
Enjoying life at the beach in SoCal...
The Master Cylinder is offline   Reply With Quote
Old 01-20-2019, 04:31 PM   #11
DHZIEMAN
I venture on a no pressure system as a model A, you could manage paste on fix, but, if you are like me, there would always be concern about it! Best to get a replacement.
Old 01-20-2019, 05:18 PM   #12
noboD
What is inside at the weld joint is called sugar. It is caused because they didn't back flow argon into the pipe before welding. They saved a few pennies in time to risk a leak.
noboD is offline   Reply With Quote
Old 01-21-2019, 12:59 PM   #13
Steves46
Steves46's Avatar
Just as I thought, Mike's will be shipping me a replacement at no cost.
Old 01-21-2019, 01:35 PM   #14
DHZIEMAN
They are good folks to deal with! On anything for my car, I look to them first!
