01-16-2022, 04:45 PM | #1 |
Checking Fluid in Rear Shocks on 31 Victoria
I am checking the fluid levels in the rear shocks of my 31 Victoria. The shocks are rebuilt by Arizona Model A and I think they are original housings. Anyway, I can't back out the fill plugs far enough to fill them. The plugs come up against the wood subframe. I will have to remove the shocks from the frame to get the fill plugs out of the hole. What is the correct position of the fill plugs? I suspect that when the shock covers where installed, the cover was placed incorrectly. The plugs are at the very top of the housing. Thank you for your comments. Ed
01-16-2022, 05:40 PM | #2 |
Re: Checking Fluid in Rear Shocks on 31 Victoria
Maybe call Sammy from Arizona A.
01-16-2022, 07:50 PM | #3 |
You can angle them slightly off center.
"The more things change, the more they stay the same." |
01-17-2022, 04:20 AM | #4 |
Not an easy fix at this point due to creating possible leakage |
