01-09-2022, 03:53 PM | #1 |
Clutch Pedal on 39 Ford came off!
I did drive it a while without realizing it was on the floor! When we stopped my wife pointed it out. The thread on the peddle looks OK. However it does not screw into the clutch lever all of the way! Same for the Brake peddle! This could be a dangerous situation if it happened at the wrong time!
Does anyone know the bolt size? Any suggestions for getting it to go all of the way in to the hole? Thanks
"Engineers like to solve problems. If there are no problems handily available, they will create their own problems!" ROGER, WILCO, OUT! |
01-09-2022, 03:58 PM | #2 |
Re: Clutch Pedal on 39 Ford came off!
They don't screw on all the way, at least the repo pads don't. Put some tape or loctite on it.
01-09-2022, 04:13 PM | #3 |
It's a tapered thread screw it in until it's tight.
01-09-2022, 04:25 PM | #4 |
Thanks! i WOULD HAVE SOLD THIS SUCKER A LONG TIME AGO HAD IT NOT BEEN FOR ALL Y'ALL ON THIS FORUM
"Engineers like to solve problems. If there are no problems handily available, they will create their own problems!" ROGER, WILCO, OUT! Last edited by Ramblin Reck; 01-09-2022 at 04:33 PM. Reason: Mo better comment! |
01-09-2022, 04:28 PM | #5 | |
Thanks!
01-09-2022, 04:30 PM | #6 |
JimVette 59 THANKS
01-09-2022, 04:30 PM | #7 |
They're 1/4 NPT pipe thread. Screw them in till they are tight.
Mart. |
01-09-2022, 05:49 PM | #8 | |
