Old 12-13-2021, 05:30 PM   #1
CA Victoria
CA Victoria's Avatar
Default Brake Switch Tee
I want to install a pressure operated brake switch.
My system has 1/4” lines, the switch has a 1/8” np thread.
I’m not finding a tee for 1/4 inverted flare w-1/8” port.
Someone else must have crossed this bridge before.
Thanks!
Tim
Downtown, Ca
CA Victoria is offline   Reply With Quote
Old 12-13-2021, 08:02 PM   #2
51 MERC-CT
51 MERC-CT's Avatar
Default Re: Brake Switch Tee
Thanks!
Perhaps use a 7/16 24 plug for the inverted flare and install a 1/8 NPT thread in it.
Old 12-13-2021, 08:03 PM   #3
Brian
Brian's Avatar
The brake lite switch screws into the back of the 91A-2077 master cylinder outlet fitting banjo bolt which holds the 99A- 2076 Tee
Unfortunately, two half wits don't make a whole wit!
Brian is offline   Reply With Quote
Old 12-13-2021, 09:17 PM   #4
richard crow
brian has it right. the trouble with a hydl. switch is the car is slowed down a lot before it lights the lights . if you install a lever switch the lights light a lot sooner giving the car behind you more warning . p.s there ez to install
richard crow is offline   Reply With Quote
Old 12-13-2021, 09:22 PM   #5
ahshoe
I replace all my Ford pressure brake light switches with homemade brackets and run a GM brake light switch off the brake pedal rod …adjustable ,immediate ,and works with DOT 5 silicone where the pressure switches won’t. Just did my 56 Ford F100 today as a matter of fact.
ahshoe is offline   Reply With Quote
Old 12-14-2021, 02:45 AM   #6
deuce lover
deuce lover's Avatar
I stopped using the pressure switch over 30 yrs ago.Here is the mech one Speedway sells and easy to install.
https://www.speedwaymotors.com/Speed...itch,1972.html
deuce lover is offline   Reply With Quote
Old 12-14-2021, 03:48 AM   #7
CA Victoria
The banjo will not work with a dual MC.
Good thought 51 Merc......that will be my plan B
Do you have a part number to share ahshoe?
Tim
Downtown, Ca
Old 12-14-2021, 07:20 AM   #8
glennpm
glennpm's Avatar
You can use an inline tee with 1/8"NPT on all branches. Get adapters for 1/4" brake tubing; 7/16-24 inverted flare brake, IFF to 1/8"NPT.
Glenn
Old 12-14-2021, 07:57 AM   #9
glennpm
glennpm's Avatar
Here's one example on Ebay
https://www.ebay.com/itm/23425423059...3ABFBM7OWNkLdf
Old 12-24-2021, 03:51 PM   #10
Ramblin Reck
Ramblin Reck's Avatar
A picture would sure help this rookie modify his 1939 Ford! Thanks
"Engineers like to solve problems. If there are no problems handily available, they will create their own problems!" ROGER, WILCO, OUT!
Ramblin Reck is offline   Reply With Quote
Old 12-24-2021, 03:53 PM   #11
Ramblin Reck
Can you post a picture of installation so I can put it on my 1939 Ford? Thanks
Old 12-24-2021, 04:16 PM   #12
V8COOPMAN
V8COOPMAN's Avatar
Here ya go! Picture this mounted on the BOTTOM side of the driver side wooden floor board. That is the brake pedal you see running vertically in picture, which allows switch arm to be activated. DD
Click Links Below __
T5 W/TORQUE TUBE
Old 12-24-2021, 04:27 PM   #13
Ramblin Reck
Thanks That helps to understand. Which switch is that?
Old 12-24-2021, 05:07 PM   #14
V8COOPMAN
V8COOPMAN's Avatar
The switch in my picture has an adjustable arm, as in the picture below. They are available at many auto parts stores, or at this eBay link BELOW!
https://www.ebay.com/itm/Universal-S...-/400327608479
I actually like the switch shown BELOW! They come in LEFT handed, or RIGHT handed. Available at THIS link BELOW!
https://kwikwire.com/products/mechan...p-light-switch
T5 W/TORQUE TUBE
Old 12-24-2021, 05:29 PM   #15
rich b
rich b's Avatar
Here's a picture of a stock GM switch screwed to the wood toe board on my '35 using a '40 pedal assy.
rich b is offline   Reply With Quote
Old 12-24-2021, 11:56 PM   #16
1948F-1Pickup
1948F-1Pickup's Avatar
Thanks!
I've run that type of switch, in just that same manner before. My F1 has a dual master on it and a "T" with a pressure switch screwed into it. Works just fine. You can't hit the pedal with any kind of pressure and not get brakes light on in the rear.....
It's 3/16 line though, with a 1/8 NPT switch.
I've not seen any "T" unions in 1/4 with anything other than 1/4 inverted flare at ALL the connections.
1948F-1Pickup is offline   Reply With Quote
Old 12-25-2021, 08:14 AM   #17
CA Victoria
Still, none of the mfg. catalogs I perused showed this tee but I did I find a fella selling what is presumably old shop stock on eBay.
File Type: jpg 0A79310C-DE2A-4F51-9BF3-DFF76946FA4E.jpg (38.0 KB, 20 views)
Tim
Downtown, Ca
Old 12-25-2021, 09:04 AM   #18
Ramblin Reck
Thanks again Merry Christmas to all
Old 12-25-2021, 10:58 AM   #19
1948F-1Pickup
Yeah. That's gotta be rare.
Old 12-25-2021, 11:43 AM   #20
glennpm
glennpm's Avatar
Still, none of the mfg. catalogs I perused showed this tee but I did I find a fella selling what is presumably old shop stock on eBay. and Someone else must have crossed this bridge before.
These are not available and therefore my posts #8 and #9 above.
