Old 11-10-2021, 02:37 AM   #1
Incognito-A
Default Home plating kits
Anyone familiar with currently available home plating kits (chrome, nickel, copper, zinc, blueing, etc) please chime in.
What is your preferred brand? Why?
Incognito-A is offline   Reply With Quote
Old 11-10-2021, 07:32 AM   #2
Mike Peters
Mike Peters's Avatar
Default Re: Home plating kits
https://caswellplating.com
I've never tried my own electroplating, but my neighbor has and was happy with the results from Caswell.
Mike Peters is offline   Reply With Quote
Old 11-10-2021, 07:39 AM   #3
Oldbluoval
Oldbluoval's Avatar
I’ve “heard” from buddies that they are decent for copper and cadmium. Nothing further on chrome and nickel
Oldbluoval is offline   Reply With Quote
Old 11-10-2021, 09:21 AM   #4
aermotor
Any one heard of dipping small parts in molten aluminum foil?
John
aermotor is offline   Reply With Quote
Old 11-10-2021, 09:33 AM   #5
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
The Caswell stuff from my experiences work fairly well on the Cadmium stuff however the time you spend to do it is WAY more than the expense that you can have it professionally done. Cadmium plating done commercially is not expensive.
Flash plating items in Nickel is met with mediocre results using Caswell methods. The prep work (-which has nothing to do with the Caswell offerings) is what makes or breaks the quality of the job. What I have learned is, I can strip the part of the previous plating, do the prep work (buffing, sanding copper, etc.) and then take the 'ready to be dipped' piece(s) to my local plater for them to actually plate and get a MUCH superior job than what I was getting from Caswell kits, and not spend much money for the plating. It is the prep work before dipping that causes the price to be expensive.
Caswell offers good chemicals for Raven finishing hardware.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 11-10-2021, 11:05 AM   #6
Incognito-A
Caswell seems to be the big name in the home plating space.
Any rival companies worth a look?
Old 11-10-2021, 11:14 AM   #7
katy
katy's Avatar
FWIW, to do chrome or nickle plating, the object has to be copper plated first.
Old 11-10-2021, 11:31 AM   #8
Incognito-A
Nickel (& chrome, I believe) may be plated directly onto other than copper base metals. It depends on the process and preparation.
Old 11-10-2021, 11:42 AM   #9
burner31
burner31's Avatar
Being a electroplater for over twenty years I can say stylus plating works great.
I have plated chrome, nickel, gold, silver, cobalt, copper, and a host of other metals, both for cars, motorcycles, farm equipment and space/aircraft. (You should see some of my gold plated coins and other items)
I have traveled to every part of the Country repairing aircraft for the DOD using this method, hell, I even used it on the Shuttle...when it was flying.
I have the portable equipment, I just don't have the chemicals anymore (retired)
Should I sell my plating equipment?
So to answer your question...look into stylus plating
Keith
Shawnee OK
'31 SW 160-B
burner31 is offline   Reply With Quote
Old 11-10-2021, 12:50 PM   #10
jwmckenzie
Yes, Nickel and chrome and many others can be plated directly on various metals. Copper is used under these as a way to smooth out pits and other imperfections. The copper is plated because it is a soft metal then buffed smooth. The nickel and chrome is plated over the copper. Think of the copper as Bondo for plating.
jwmckenzie is offline   Reply With Quote
Old 11-11-2021, 07:11 AM   #11
nkaminar
nkaminar's Avatar
Please be careful with the chemicals. Most are very toxic and/or corrosive.
Old 11-11-2021, 01:56 PM   #12
Oldbluoval
Oldbluoval's Avatar
Most chrome directly over steel that I’ve seen peels in a short period.
And rusts quickly
Old 11-11-2021, 03:17 PM   #13
Ed in Maine
I know I will be criticized for this suggestion but here goes. Take a look at Rust-Oleum Metallic as an alternative to Cadmium Plating. It is called #7277830 Metallic Matte Nickel. From two feet away, it looks pretty good for small parts. Ed
Ed in Maine is offline   Reply With Quote
Old 11-11-2021, 05:42 PM   #14
Incognito-A
Eastwood also has/had a copycad product which was a paint as well for cad and zinc. There’s room for everyone Ed, although I personally prefer the real thing.
Old 11-11-2021, 09:37 PM   #15
burner31
burner31's Avatar
Small parts? I've used that on bumpers, looks good and touches up easily, you work with what you have
Keith
Shawnee OK
'31 SW 160-B
Old 11-12-2021, 12:23 AM   #16
California Travieso
Send a message via Yahoo to California Travieso
I picked up a front 30-31 bumper for $20 at swap meet that was painted like that. I’m going to use it on my 30 roadster until I get the body and fenders painted.
David Serrano
California Travieso is offline   Reply With Quote
