12-28-2021, 12:39 PM | #1 |
Seeking advice - Seat riser/base repair
Started cleaning up the '31 AA and assessing what needs fixed and/or replaced. The seat riser is in need of repair, lots of rust and one of the seat back mounting locations is basically gone.
What advice can the seasoned owners/restorers advise in this situation? I'm building this truck as a tinkering hobby project with plans of driving it and enjoying it, not a show vehicle. At the same time I don't want to completely compromise the original craftsmanship with a lack luster repair. Are reproduction parts in this situation advised or frowned upon? I've read a lot of posts with varying experiences on reproduction parts and a little torn on a direction here. Forgive my naïve questions, I'm new at this restoration stuff and trying to not make a mistake I'll regret down the road. Thanks. |
12-29-2021, 10:01 AM | #2 |
Re: Seeking advice - Seat riser/base repair
I’m not able to see the damage you reference. Perhaps a bit more detailed description will help clarify the situation. That said, the reproduction replacement panels are pretty good. Or if the area is fairly small and you are capable of cutting it out and welding in a patch may be another solution.
12-29-2021, 11:04 PM | #3 | |
(I also acknowledge its possible I'm completely overthinking this repair ) |
12-30-2021, 08:15 AM | #4 |
Depends on what u find acceptable. Welding around rusted metal without a good cleanup to good metal is treacherous because what may look solid…..is not. It blows away with welding
The repos are decent |
12-31-2021, 06:55 AM | #5 |
since its basically hidden-your call.
most would repair and move on. if its just going to be a driver. show car? get a fresh one or do the repair right. |
12-31-2021, 11:51 AM | #6 | |
What I was figuring someone would say, makes sense. I appreciate the feedback. The rest of the riser isn't in too bad a shape so repairing the damaged mount makes the most sense. Thanks. |
12-31-2021, 01:28 PM | #7 |
All depends on your intentions. The area you show .......... as is ........ is not a point of no return. But, as Old Blue Oval suggests, welding in a piece might lead to further problems. If your intent is to just “ fix that issue” and move on, pop riveting a piece of flat stock wherever that back piece is structurally sound will fix the integrity of that part and you can move on. Mechanically speaking, you’ve fixed the problem. If you want “restore”, drill out the rivets holding the piece in, clean it, sandblast it, and then ........... when you have a clear picture of overall condition and structural integrity ........... make an advised decision as to how to proceed. But, know that, as others have said, this part in reproduction is pretty good on all counts.
Good luck with your project. Bob Bader |
01-01-2022, 11:32 AM | #8 |
It looks solid enough to cleanup, cutout rust, make sheet metal patches and weld the patches in. My seat base for my Model A was rusty with many fatigue cracks. But when I got done with it, I still have an original part that is perfectly functional. I get a lot of satisfaction with that. It is what restoration is all about. Ed
01-03-2022, 06:35 PM | #9 | |
01-03-2022, 06:36 PM | #10 | |
01-04-2022, 08:41 AM | #11 | |
I do concur with many others above that repairing that one would be the simplest for us. |
