01-04-2014, 12:18 PM | #1 |
stuck in the 60's
Machinist quoted $250.00 to replace the plugs and grind crank .010-.010 on 51 merc crank. Is that excessive or am I stuck in the 60's? Thanks, Harley
people have more trouble than anybody |
01-04-2014, 12:27 PM | #2 |
Re: stuck in the 60's
With the high hourly rates, I'd say if done right its worth it.
01-04-2014, 12:41 PM | #3 |
I just had a Merc crank ground (.010/0.10) at Hunt's Machine in Albany, New York (http://www.huntsmachine.com/index1.htm). I
get a discount because I go thru a friend who has a shop but no crank grinder ($$$$$$$$). $108 for the grind, $19 for degrease, and $25 to shot blast the crank. I had removed the crank cleanout plugs and replaced them when I got it back. Excellent work. Just be sure you check out their work. John |
01-04-2014, 05:51 PM | #4 |
I see that the wise men have turned their backs on your crank and the dog does not seem very interested. I would say that your crank is suspect.
01-04-2014, 06:26 PM | #5 |
If I were paying I would think it's a lot of $$$$ But if I was doing the work I would say MAN we have got to get these rates up..... When you consider the cost of the machine / the cost of opperating a buisness / the paper work to cover the cleaning fluids & cutting oils. Unfortunately it 2014 not 1960!!!! |
