Old 10-26-2020, 02:15 PM   #1
52 Ford
Default 52 Ford no heater
I do not plan on using a heater for now in my 52 Ford. What can or should i do with the outlet from the head and the inlet at the water pump? Should I run a hose from one to the other or just shut off the summer bypass and plug the water pump opening?
52 Ford is offline   Reply With Quote
Old 10-26-2020, 02:26 PM   #2
Joe KCMO
Joe KCMO's Avatar
Default Re: 52 Ford no heater
Shut them both heads off with the correct shutoff valves. Plug the pumps .
Joe KCMO is offline   Reply With Quote
Old 10-27-2020, 10:08 AM   #3
RalphG
RalphG's Avatar
On my 52 Merc I just have a piece of heater hose to connect the two outlets and by pass the heater core. I don't plan on running it in real cold weather plus I don't know if the core leaks.
RalphG is offline   Reply With Quote
