Old 09-15-2021, 07:22 AM   #1
CatMan1
Default Wrong Gear Oil?
I think I read somewhere that if too light of a gear oil is added to the transmission/rear end it will cause it to leak. Is that true? I know both of mine are. It's light enough that it can drip off my finger and it's kind of dark. Also, what difference, if any, would it make in shifting?
CatMan1 is offline   Reply With Quote
Old 09-15-2021, 08:00 AM   #2
LeonardS
Default Re: Wrong Gear Oil?
I use Texaco Meropa 680. It comes in 5 gallon buckets and I bought it from one of the oil suppliers in Des Moines when I lived in Iowa.
LeonardS is offline   Reply With Quote
Old 09-15-2021, 08:10 AM   #3
CatMan1
Well, I do live 40 miles from there.......
Old 09-15-2021, 08:16 AM   #4
Patrick L.
Patrick L.'s Avatar
Its easy enough to change it and not worry about it.
I don't see any difference between 140w and 250w. Its available at Restoration Supply Co. The Meropa should be just fine also.
From what I understand the 600W available today is doctored up 140w.
Is the transmitter actually leaking, or, is it the u-joint clamshell ?
Old 09-15-2021, 08:21 AM   #5
CatMan1
I haven't checked that close yet. Too many other issues. I think it was on the bottom of the transmission.
Old 09-15-2021, 10:51 AM   #6
Ruth
Probably leaking from the reverse idler and cluster gear shafts. The vendors have a kit that stops that annoying leak. https://www.snydersantiqueauto.com/P...earchByKeyword
Replacement shafts have a 'o' ring.
Ruth
Old 09-15-2021, 03:26 PM   #7
rotorwrench
rotorwrench's Avatar
The recommended lubricants are dictated by the manufacturer. Outdated lubricate grade ratings generally always have a modern equivalent. Seal technology back in the early automotive era was not as good as it is today but it kept the majority of the lubricant inside where it belongs. It's after the seals deteriorate and clearances wear when it gets harder to keep the lube in. Renew the seals and seal up any clearance gaps and the units should still hold their mud.
Old 09-15-2021, 04:02 PM   #8
Oldbluoval
Oldbluoval's Avatar
Another issue is that the A tranny in not synchronized. The heavy dope helps the shifting process. I’ve not tried thinner oil but would think leaking would also be an issue.
Oldbluoval is offline   Reply With Quote
Old 09-15-2021, 07:28 PM   #9
nkaminar
nkaminar's Avatar
Mitchell recommends 85W-140 GL5 gear oil for their transmissions and overdrives for the Model A. Oils have come a long way in 90 years and the modern oils have additives to maintain the oil film under pressure. The 85W-140 is fairly thick oil. I use it in my transmission and rear end.
If the transmission is too full it will leak. New gaskets and seals will stop leaks.
Old 09-15-2021, 11:17 PM   #10
eagle
eagle's Avatar
My experience: I have used Lucas Oil Stabilizer in my A transmission for years. Makes the shifter silky smooth. The "600W" oil I got from the vendors was not good. Try it yourself, Stopped the oil drip on mine too.
"There are some that can destroy an anvil with a teaspoon and shouldn't be allowed to touch anything resembling a tool."
eagle is offline   Reply With Quote
Old 09-16-2021, 09:36 AM   #11
Chris in WNC
Chris in WNC's Avatar
I have used straight STP in transmission/differential/steering box for the last 15-20 years.
Many miles and no problems.
our next Model A is out there in the unknown......
Chris in WNC is offline   Reply With Quote
Old 09-16-2021, 11:04 AM   #12
rotorwrench
I'll bet it takes a while to change out that STP viscosity builder product. Straight SAE 250 would be easier to change than that stuff.
Old 09-16-2021, 06:40 PM   #13
Synchro909
Synchro909's Avatar
A thin gear oil will make gear changing more difficult to do silently IMO.
I'm part of the only ever generation with an analogue childhood and a digital adulthood.
Old 09-16-2021, 07:41 PM   #14
Crankster
Crankster's Avatar
One thing to keep in mind when reading lubricant specifications, Gear Oil numbers are different than SAE Oil numbers for equivalents, and I think the old 600W, SAE 50, and 90W Gear Oil are all pretty close in terms of viscosity.
Crankster is offline   Reply With Quote
Old 09-17-2021, 08:23 AM   #15
Patrick L.
Patrick L.'s Avatar
600W is more in line with 180-240W. 140 and 250 work fine as stated. 90 is to light. This is discussed very often here.
Old 09-17-2021, 08:32 AM   #16
Bob Bidonde
Bob Bidonde's Avatar
I have been running SAE high pressure gear oils since 1962, and recently I use 75W140 GL5 synthetic blend. In fact, gear shifting is not difficult! I always double clutch to avoid grinding the gears.
Bob Bidonde
Old 09-17-2021, 10:54 AM   #17
rotorwrench
The Society of Automotive Engineers had different systems for grading viscosity standards between motor oil and gear lubricant products. SAE 50 motor oil is in the same viscosity range as SAE 90 gear lubricant. The API is also part of the current rating system. All are still SAE or ISO rated but the type of lubricant has to be included to tell what the rating is for. Motor oils used ZDDP for tappet protection but gear lubes have extra pressure or EP additives designed for gears for an EP rating in similar fashion as grease products but grease products have there own ratings and extra pressure additive packages so they are all in their own separate categories. ATF & Hydraulic fluid are also in different categories.
The SAE is still used in the US but the International Standard Organization or ISO still takes precedence in the modern era.
Old 09-18-2021, 09:06 AM   #18
Chris in WNC
when changing the STP in trans and diff, I just open the drain plugs and come back a few days later......
steering box does not get changed, just topped off as needed.
