Old 09-12-2017, 09:00 AM   #1
Henry Floored
Henry Floored's Avatar
Default 1941 Ford side window "anti rattler felts"?
Guys I'm not even sure what to call them but I would like to replace those hairy things that seal and secure the side windows in my '41 Coupe.
I purchased a beautiful kit from Bob Drake. Really spot on parts and I'm very happy with them.
My question is the original parts have holes through which a spring clip is inserted and this attaches the felts to the inside of window open in the door on each side of the glass.
How do you guys put those holes in the felts. The spine of the felts is very delicate and I don't want to muss things up.
Any advice or first hand experience would be greatly appreciated.
Henry Floored is offline   Reply With Quote
Old 09-12-2017, 09:20 AM   #2
40cpe
40cpe's Avatar
Default Re: 1941 Ford side window "anti rattler felts"?
There are some very small metal screws that you use to attach the fuzzies. The head of the screw is cone-shaped on the bottom and flat on the part that the screwdriver fits in, like a wood screw. Position the fuzzy and drill through it and the metal. The head of the screw will bury in the fuzzy and never be seen or touch the glass.
40cpe is offline   Reply With Quote
Old 09-12-2017, 09:20 AM   #3
corvette8n
corvette8n's Avatar
I'm watching for the answer also, found a Drake kit in my truck that the previous owner left.
Old 09-12-2017, 09:21 AM   #4
Krylon32
After struggling with the repro felts I started using the fuzzy side of stick on Velcro between the window and door and the window and the garnish. I have done this for several years and once you stick it on it stays. I know it's not concourse perfect but it works.
Krylon32 is offline   Reply With Quote
Old 09-12-2017, 10:29 AM   #5
cmbrucew
cmbrucew's Avatar
Thank you
That trick can/will save lots of time and frustion. Now if you had a way of attaching the little ss edge to the Velcro.
Bruce
Works good
Lasts long time
cmbrucew is offline   Reply With Quote
Old 09-12-2017, 11:06 AM   #6
Fibber Mcgee
Fibber Mcgee's Avatar
I just did all my 41 tudor and I used the screws. Laid it on the door and drilled thru both at the same time , for the garnish I used the supplied staples drilling 2 holes for the staples . Everything went in easy and fit perfectly.
Wanted, a car with a " Dynaflex Superflowing Unijet Turbovasculator which is Syncromeshed to the Multicoil Hydrotensioned Dual vacuum Dynomometer. "
Fibber Mcgee is offline   Reply With Quote
Old 09-12-2017, 02:56 PM   #7
Tony, NY
If you don't like the screws, try using silicone to glue them on. I've used it. Tape or clamp them overnight.
Tony, NY is offline   Reply With Quote
Old 09-13-2017, 01:31 AM   #8
Graeme / New Zealand
Graeme / New Zealand's Avatar
Did the same Fibber (and drilled through the side my finger doing the garnish)
GB
"you can't make honey out of dog sh*t"
"You're a long time looking at the lid"
Graeme / New Zealand is offline   Reply With Quote
Old 09-13-2017, 09:25 AM   #9
41Joe
41Joe's Avatar
Where do you get the screws or staples? I am going to have to do this for my 41 Tudor soon. I like the fuzzy velcro idea, but I want to have that stainless steel edge.
41Joe is offline   Reply With Quote
Old 09-13-2017, 02:43 PM   #10
Lawson Cox
Lawson Cox's Avatar
Roy Nacewicz has the screws.
Old 09-13-2017, 04:58 PM   #11
Henry Floored
Good stuff guys, thanks!
Old 09-15-2017, 07:00 AM   #12
mike42
mike42's Avatar
When I replaced mine on '40 Sedan....I used a very sharpe pin point punch on a wooden bench. New heavy staples came with the anti-rattles and I had no probs at all. They have held very well and did not bend them when using the punch.
mike42 is offline   Reply With Quote
Old 09-15-2017, 08:33 AM   #13
325w
You can use Phillips screws I'm thinking number 4. Clamp the fuzzie drill one screw at a time. Done many of these. On the garnish you may have to cut the screw off on the back side.
325w is offline   Reply With Quote
Old 09-16-2017, 07:22 AM   #14
edhd58
edhd58's Avatar
I got my kit from Bob Drake also. It came with the Staples I pre drilled all the staple holes to match the original holes in my door metal and inside trim metal push them through and use needle nose pliers to curl the back sides around to tighten everything up took a while but it looks good.
edhd58 is offline   Reply With Quote
Old 09-16-2017, 06:11 PM   #15
Henry Floored
My doors have pre drilled holes. The originals have a spring clip which pushes through the felt backer and into the hole in the door.
I'm worried that a drill bit might grab and damage the felt. I'm seriously considering on taking an awl and a block of wood and punching a hole through.
