Old 04-16-2018, 07:19 PM   #1
Greg58
Greg58's Avatar
Default Under Car Antenna
I know this has been asked before, but since I can't search this forum on my tablet i'll ask. I installed a radio in my car and didn't want to mount the antenna through the fender, I mounted a full length expanded antenna on the outside of the frame on the passengers side. On the small end I put a 10 inch length of hose and extended the antenna through the triangle floor brace. The hose keeps the mast from touching. This works great sitting still, the funny thing as I start getting up to speed the reception fades, at 60 mph you can't hear the radio. As soon as I slow reception returns, any ideas?
Greg
Greg58 is offline   Reply With Quote
Old 04-17-2018, 06:54 AM   #2
chap52
chap52's Avatar
Default Re: Under Car Antenna
Thanks for the memories Greg. In the 60's we would do underbody mounts of the antennas when we were stripping chrome, filling holes and "frenching" headlights. Don't remember ever having a problem with reception. There were/are some special antennas out there. Take a look at this option: https://www.crutchfield.com/p_12044U...l-Antenna.html
Enjoy the adventure, Chap
Old 04-17-2018, 07:17 AM   #3
51 MERC-CT
51 MERC-CT's Avatar
That's assuming that there is a 12 volt source available to operate it.
Old 04-17-2018, 10:00 AM   #4
Kurt in NJ
Kurt in NJ's Avatar
Was the trimmer capacitor adjusted to the antenna after installation
Old 04-17-2018, 01:37 PM   #5
Greg58
Greg58's Avatar
I've never had anything like this before thats why I asked. I converted it over to 12v neg. ground about 15 years ago so power to a antenna will not be a problem. I have a second antenna that I thought about adding, does a antenna cable splitter work.
Greg
Old 04-17-2018, 01:43 PM   #6
Kurt in NJ
Kurt in NJ's Avatar
Somewhere on the radio, usually near where the antenna wire goes in there is a small adjustment screw--- on these old am radios it makes a lot of difference in reception, set radio at weak station in lower numbers, adjust for best reception
Old 04-17-2018, 01:47 PM   #7
Greg58
Greg58's Avatar
Thanks but mine is a custom auto sound radio, I wanted f.m.
Greg
Old 04-18-2018, 06:31 AM   #8
buzz4041
buzz4041's Avatar
I have the same setup as you and the reception has never been good. I put a under dash Tune trapper in and it does about the same. I have learned to just plug in the Ipod and forget about radio.
buzz4041 is offline   Reply With Quote
Old 04-18-2018, 07:54 AM   #9
joe plumber
I put the antenna under the dash of my 55 f100,works great.
joe plumber is offline   Reply With Quote
Old 04-18-2018, 11:49 AM   #10
joe plumber
I also have a modern radio
