03-25-2020, 01:54 PM | #1 |
Columbia 2 speed A-7 differential baffle
Can someone please post a picture of a A-7 differential carrier baffle? Also how it looks installed? It looks like a ring in the heavy cast iron adapter.
Thanks Last edited by uncle buck; 03-25-2020 at 02:03 PM. |
03-25-2020, 04:51 PM | #2 |
Re: Columbia 2 speed A-7 differential baffle
You're in luck I happen to have mine apart. It's just pinched in there.
03-25-2020, 08:32 PM | #3 |
Thanks @Solidaxle , can you show me how it fits in the housing? I have several boxes of disassembled parts I am trying to lay out
03-25-2020, 09:46 PM | #4 |
Ok I see how goes, had to get a second casting to study. Thanks for your pictures to give an idea what it is.
03-25-2020, 10:47 PM | #5 |
If I remember correctly, it is staked into the casting. I had 1 casting that it was missing from.
03-25-2020, 11:02 PM | #6 | |
It appears so. I have one it is missing from also, but fortunately I had an extra that had it too. I didn't visualize it being that big around and I had nothing like it loose in my boxes |
03-26-2020, 07:46 AM | #7 |
You must know John at Columbiatwospeedparts.com, He's the expert on these things.
03-26-2020, 08:29 AM | #8 | |
Yes, he did his bulletproofing treatment. When I got unit, it was apart and everything was in boxes with a mixture of stuff that doesn't belong. I have been studying the exploded view and trying to sort through everything to take to a friend to be assembled. Thanks for your help |
03-31-2020, 11:46 AM | #9 |
What's the function of that baffle?
03-31-2020, 02:50 PM | #10 |
The rotating A-17 assembly has paddles on the outside that take the oil and direct it into the A-6 oil passage. This is how the bearing, planetary gears and shafts plus the sun and the clutch get their necessary oil. The A-7 baffle help to hold the oil in place for the paddles on the A-17.
