11-30-2021, 12:46 AM | #1 |
Power steering
Anyone ever put power steering on a Model A. I know It would be a lot of machine & designing involved. Its only nut & bolts.
11-30-2021, 09:10 AM | #2 |
Re: Power steering
As a teenager 50+ years ago my A was so hard to turn! on ice I got stuck against a curb. Putting it reverse got out and pushed it away from the curb jumped in went home. I removed the steering column and went through it, followed the service bulletin on adjusting and presto …… power like steering!
11-30-2021, 09:23 AM | #3 |
Re: Power steering
I have retrofitted power steering onto bigger Horseless Carriage (-pre teen) vehicles using a modern Ford tractor assist cylinder and a Chevy Cavalier pump. Electric pumps are becoming more prevalent (i.e.: affordable) which might make the job easier on vehicles with a charging system. The job you are seeking is very do-able however the costs associated may be the deterrent.
11-30-2021, 02:13 PM | #4 |
Re: Power steering
I have a steering box from an F-100 Ford pickup. It uses the same hand controls, light switch, and steering wheel as a stock Model A. The steering is so easy it is like having power steering. I rebuilt the box. Parts are available. It has one adjustment so easy to take all the slack out.
I should add that a lot of the difficulty in steering is due to worn front axle parts, like the king pins and not having the front axle aligned correctly.
11-30-2021, 11:23 PM | #5 |
Re: Power steering
Buy a F100 unit rebuilt and ready to bolt into your A from Randy Gross. 714 292 8660
1921 Runabout 1930 Tudor Early 1930 AA Speed costs money. How fast do you want to go? |
12-01-2021, 03:54 PM | #6 |
Re: Power steering
12-03-2021, 09:12 AM | #7 |
Re: Power steering
Have you tried a shorter pitman arm?
Regards Bill |
12-04-2021, 10:34 AM | #8 |
Re: Power steering
All Model A's came with Armstrong power steering as standard equipment
12-05-2021, 04:06 PM | #9 |
Re: Power steering
was that invented by Neil Armstrong?
