Old 11-22-2021, 01:48 PM   #1
Nick in Fayetteville
Default Air Filter
How many are running an air filter and why?
Nick in Fayetteville is offline   Reply With Quote
Old 11-22-2021, 02:26 PM   #2
WHN
Default Re: Air Filter
I always have used an air filter along with engine side pans.
Keeps big things out of the engine. Never a problem with carburetor settings. Stops flash back from carb to.
Enjoy.
WHN is online now   Reply With Quote
Old 11-22-2021, 02:49 PM   #3
Kurt in NJ
Kurt in NJ's Avatar
I use air maze screen type with oil on itd
Old 11-22-2021, 04:03 PM   #4
Flathead
Flathead's Avatar
Yes, same here.
Flathead is offline   Reply With Quote
Old 11-22-2021, 04:44 PM   #5
Synchro909
Synchro909's Avatar
We are RHD so none of the filters you guys use will work except maybe the "Hiboy" one but that can't be used with one of those oil filters on the side cover kits. We have to get creative. I make a fibreglass adaptor to go from carburettor throat, out through the gap between the choke rod and the column itself, then upwards. A short length of old vacuum cleaner hose connects that to a paper element filter mounted on the radiator stays. It is tight, tight, tight in there so it can take a lot of fiddling to get it right. As I have said before, The Model A is very poorly designed for RHD - there are so many simple and cheap ways it could have been improved on the drawing board.
I'm part of the only ever generation with an analogue childhood and a digital adulthood.
Old 11-22-2021, 04:55 PM   #6
eagle
eagle's Avatar
I also use an original aftermarket AirMaze. It collects a lot of dirt so must be doing something. Does not affect the fuel mixture at all that I can notice.
"There are some that can destroy an anvil with a teaspoon and shouldn't be allowed to touch anything resembling a tool."
eagle is offline   Reply With Quote
Old 11-22-2021, 05:25 PM   #7
fried okra
Location: Daniel Island,SouthCarolina/Knoxville, Tennessee/Sanibel Island,Florida
My Weber carb for a Model A came with an air filter. Therefore, it was jetted to run with one.
If I was running a stock carb, not sure what I would do.
fried okra is offline   Reply With Quote
Old 11-22-2021, 07:40 PM   #8
Mulletwagon
Mulletwagon's Avatar
I use a K&N highboy setup and like it. As for whether to use a filter or not - the jury is in - filter. Sucking in abrasive particles and damaging cylinder walls of our cherished engines would be unwise.
Mulletwagon is offline   Reply With Quote
Old 11-22-2021, 08:19 PM   #9
clifforddward
clifforddward's Avatar
Back in the 1980s I ran a K&N type air filter in my 68C....seemed like small price to pay to keep the large particles out of the engine....never any problems over the several years I used it.
clifforddward is offline   Reply With Quote
Old 11-23-2021, 12:38 PM   #10
CarlG
CarlG's Avatar
I use a K&N filter on my Stromberg 97 because my engine builder said so.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 11-23-2021, 12:47 PM   #11
Synchro909
Synchro909's Avatar
I run the filter setup outlined in post #5 for longevity of the engine. I often drive in dusty conditions and don't feel like paying for another rebuild any sooner than absolutely necessary.
Old 11-23-2021, 05:55 PM   #12
Bob-A
Bob-A's Avatar
Thumbs up Re: Air Filter
Originally Posted by Flathead View Post
Yes, same here.
Ditto! Except I used K&N air filter spray on oil.
Bob-A
Bob-A is offline   Reply With Quote
Old 11-23-2021, 06:17 PM   #13
Gene F
Gene F's Avatar
I have an air filter on my carb in the past. Took the pleated paper element out, and used that cage with a length of paper pleated furnace filter in between the cages. low reisteance... I have not yet fitted it onto the new engine.
Gene F is offline   Reply With Quote
Old 11-23-2021, 06:28 PM   #14
nkaminar
nkaminar's Avatar
My Weber down draft comes with a filter. The carburetor compensates for any added air resistance. It is mounted up high out of the way of rocks and dust kicked up by the tires. I just replace the old filter element which was dirty.
Old 11-24-2021, 04:05 PM   #15
Ivan in southeast va.
Ivan in southeast va.'s Avatar
I took the filter off but left the curved pipe that points down on. Unrestricted and pointing down for safety.
Ivan in southeast va. is offline   Reply With Quote
Old 11-24-2021, 05:43 PM   #16
burner31
burner31's Avatar
Air filter cause problems when used on Model A's, if you are hell bent on using something...make that something an air maze.
Keith
Shawnee OK
'31 SW 160-B
burner31 is offline   Reply With Quote
Old 11-24-2021, 06:23 PM   #17
old ugly
old ugly's Avatar
i run an air cleaner because it keeps the dirt out of the engine.
do you have an air cleaner on you modern car?
old ugly
my old father-in-law told me. "listen close when people tell you how to do stuff they may know something. then do it the way you want."
old ugly is offline   Reply With Quote
Old 11-24-2021, 07:41 PM   #18
Synchro909
Synchro909's Avatar
I can guess but I'm not sure I know exactly what an air maze is. I'm expecting it is some air cleaner that suits only LHD cars and that's why I haven't seen one.
Old 11-24-2021, 08:32 PM   #19
Ruth
Air Maze https://www.snydersantiqueauto.com/p...9483&cat=41659
Ruth
Old 11-24-2021, 09:36 PM   #20
chrs1961815
chrs1961815's Avatar
Air maze was an original aftermarket accessory that everybody seems to remember simply because the design was duplicated many times over the years. There was probably some different designs in the era, might be in the unauthorized accessories book.
"The more things change, the more they stay the same."
chrs1961815 is offline   Reply With Quote
