Old 10-20-2021, 01:41 PM   #1
rer_239
rer_239's Avatar
Default Front hub inner bearing race
How do I got the old race out?
Tia
Dick
rer_239 is offline   Reply With Quote
Old 10-20-2021, 04:15 PM   #2
Conaway2
Conaway2's Avatar
Default Re: Front hub inner bearing race
I use a hammer and punch.
Conaway2 is offline   Reply With Quote
Old 10-20-2021, 09:07 PM   #3
quickchange
quickchange's Avatar
run weld around inside of any & it shrinks them
quickchange is offline   Reply With Quote
Old 10-21-2021, 02:21 AM   #4
john charlton
john charlton's Avatar
You should really use a KR Wilson puller but they are hard to find . You can use a punch with a round head not chisel ended . If you look down the outer bearing hole you will see the "lip" of the inner race . You can then engage the punch and start to knock out the race . Vary where you hit so you do not rock the race too much so you do not stretch the land where the bearing sits If the land gets stretched the new race will be a loose fit ,not good . Take your time no rush I use a propane torch to heat the area it makes it a bit easier to punch it out .To fit the new race I heat the land and put the new race in the freezer for a while and then punch it in vary where you hit so it goes in square .
John in rainy morning Suffolk County England .
john charlton is offline   Reply With Quote
Old 10-21-2021, 06:44 AM   #5
jak
Bratton's has a tool that will remove both the inner and outer races.
https://www.brattons.com/FRONT-HUB-I...ductinfo/1772/
jak is offline   Reply With Quote
Old 10-21-2021, 06:56 AM   #6
updraught
updraught's Avatar
Youtube is your friend.
https://www.youtube.com/watch?v=EB4bE-KYkm8
You may need a variety of punches. Always wear eye protection from chips exploding off a punch.
updraught is offline   Reply With Quote
Old 10-21-2021, 07:39 AM   #7
Russell Reay
I found that the race lip which protrudes into the axle passage is so thin/ narrow that I couldn't get purchase with any of my drifts. I ground a hook into this chisel, and it worked perfectly. The guy in the video uses a 3/8 breaker bar as a drift. IMO that tool could rest against a shelf, but not a narrow lip. He and others have recommended significant force of blows to move the race. I was reluctant to do that not knowing what I might damage in the process. Several taps around the perimeter of the race dislodged it, and it came out with no difficulty.
Russell Reay is offline   Reply With Quote
Old 10-21-2021, 05:10 PM   #8
Flathead
Flathead's Avatar
Don't use a hardened steel punch on any bearing you may want to use again, the bearing can chip or crack. Brass is best but soft steel will work well too.
Flathead is offline   Reply With Quote
Old 10-21-2021, 05:13 PM   #9
jimvette59
jimvette59's Avatar
I have used a old screw driver. My bad !
jimvette59 is offline   Reply With Quote
Old 10-22-2021, 02:35 AM   #10
rer_239
rer_239's Avatar
Finally got it out and replaced.
Thanks
Old 10-22-2021, 04:55 AM   #11
Bcat
Good work!
Bcat is offline   Reply With Quote
Old 10-22-2021, 01:50 PM   #12
Patrick L.
Patrick L.'s Avatar
I just punch them out and then grind the outside diameter to side into the hole. Then use that to drive/press in the new one.
Old 10-22-2021, 01:53 PM   #13
Tim Ayers
Jak,
Thanks for posting. This looks like a great tool. Has anyone used this? Does it work as nice as it looks?
Thanks,
Tim
Old 10-22-2021, 05:19 PM   #14
JoeCB
JoeCB's Avatar
U- Tube ... well sometimes, maybe. As soon as I saw flip-flops, a claw hammer and the wrench flex handle for a punch I knew that we were dealing with a expert mechanic
Joe B
JoeCB is offline   Reply With Quote
Old 10-23-2021, 12:08 PM   #15
katy
katy's Avatar
Joe B
Another clue that it's an expert is that at the start it says: "having trouble removing the racer plates in the hubs of your tire?"
Old 10-23-2021, 12:58 PM   #16
Patrick L.
Patrick L.'s Avatar
Originally Posted by katy View Post
another clue that it's an expert is that at the start it says: "having trouble removing the racer plates in the hubs of your tire?"
:d:d:d:d:d:d
Old 10-23-2021, 05:33 PM   #17
Kurt in NJ
Kurt in NJ's Avatar
My bearing punch is old oil pump shaft
Old 10-24-2021, 06:09 AM   #18
updraught
updraught's Avatar
Recently i posted a video of roads in a very remote area and a guy was using a chainsaw with flip flops as you call them. So i'm improving my safety aspects as I go along. And added the safety glasses.
Old 10-24-2021, 07:00 AM   #19
Patrick L.
Patrick L.'s Avatar
Flip-flops and a chainsaw ? They're a long way apart, can't see a problem. [smiley face]
Old 10-25-2021, 11:57 PM   #20
redmodelt
redmodelt's Avatar
I read someplace not to use brass to drive them out or in? I, too, grind the perimeter of an old bearing to seat the new one.
