09-13-2021, 06:11 PM | #1 |
1935 fuel sending unit
Could some kind soul please post a pic of the fuel sending unit on a 35 fordor? In looking at mine, I think a wire is missing, which may explain the inoperable gas gauge. Mine simply has a wire going to it, but does not seem to have a ground. Oh, and it needs to be a 35 - apparently the 36 is different.
Thanks in advance. (attached is what I'm dealing with). |
09-13-2021, 06:37 PM | #2 | |
Re: 1935 fuel sending unit
09-13-2021, 06:40 PM | #3 |
It appears you have a jerry rig outfit there, part hydrostatic and part electric. Which one are you trying to fix?
09-13-2021, 06:41 PM | #4 |
Well, I assume the one on the right. The thing that looks like another wire going up is actually just insulation.
09-13-2021, 06:57 PM | #5 |
The 1935 Ford did not have an electric fuel gauge, The electric sender unit pictured has been added to the tank along with an electric gauge in the dash. The original hydrostatic air gauge fuel sender unit can be seen in the left of your pic which also acts as a fuel pipe pick up and also as a tank vent.. The first electric fuel gauges came out in 1936 model year. The ground for the electric fuel sender is via the metal fuel tank to the chassis frame. Regards, Kevin.
09-13-2021, 07:09 PM | #6 |
09-13-2021, 07:41 PM | #7 |
Why do you think the sender unit is not getting a ground ? Is your gauge not working ? That wire that is curving around could be a ground wire but photo is not good enough to see where it is connected. Regardless the sender unit is probably getting a ground through its tank mounting. Regards, Kevin.
09-13-2021, 10:46 PM | #8 |
@koates - No, the gauge doesn't work. It only reads completely empty. I'm working on figuring out why (I know there are several reasons) but it doesn't look to me that there is proper ground to the sending unit, especially when there is a screw right next to it.
09-13-2021, 11:20 PM | #9 |
ground the wire that has the black shrink while watching the dash gouge ,the indicate needle should rise ,
09-13-2021, 11:31 PM | #10 |
Has the original gauge on the dash been replaced or a 36 electric gauge replacement?
09-20-2021, 04:12 PM | #11 |
@deuce lover - it has a 36 electric gauge
