Old 11-20-2020, 05:20 PM   #1
56sedandelivery
56sedandelivery's Avatar
Default 56 fender apron retainer
May have asked this before. Does anyone know where you can find the fender apron retainer. Looked everywhere and even tried the t-bird ones but they are off too much. Part number 16050. Thanks
56sedandelivery is offline   Reply With Quote
Old 11-20-2020, 06:06 PM   #2
frank long island
frank long island's Avatar
Default Re: 56 fender apron retainer
try restoration specialties
frank long island is offline   Reply With Quote
Old 11-20-2020, 07:25 PM   #3
56sedandelivery
Looked thru their catalog and looks like they have clips and molding. Only fender parts I found were for the 60s mopar products.
Old 11-21-2020, 08:38 AM   #4
KULTULZ
KULTULZ's Avatar
Post Re: 56 fender apron retainer
I do not see Basic Part Number 16050 in the MPC TEXT lineup.
Do you see the BPN of what you are looking for in the below ILL?
KULTULZ is offline   Reply With Quote
Old 11-21-2020, 09:28 AM   #5
raceron1120
raceron1120's Avatar
16050 is there, it's black starred (not serviced) in the illustration at the time that pub was printed so won't be in the text section. It looks more like a retainer PANEL, not just a clip.
raceron1120 is offline   Reply With Quote
Old 11-21-2020, 09:40 AM   #6
raceron1120
Old 11-21-2020, 10:51 AM   #7
KULTULZ
KULTULZ's Avatar
Thumbs up Re: 56 fender apron retainer
I stand corrected. Short eyeballs ...
Only having FINAL EDITION limits particulars.
THANX for bringing that to light ...
Old 11-21-2020, 06:57 PM   #8
KULTULZ
KULTULZ's Avatar
While not what you are looking for, may be interested -
https://www.ebay.com/itm/1955-1956-F...-/191453855533
Close - https://thunderbird.musclecarsandcla...tainer-1955-57
Here is a defunct ad from EvilBay showing 55/56 FORD (Thumbnail Below) - Appear Same As BIRD
Here are various other pieces - http://lbcunited.com/earlyford2/inde...sort/3a/page/2
https://www.ebay.com/itm/1954-1955-1...-/352358147895
Old 11-21-2020, 07:30 PM   #9
56sedandelivery
Actually bought a set of the t-bird ones. While they are close the dimple is offset about 3 inches so that it does not line up right. May have to get some sheet steel and bugger up something.
Old 11-21-2020, 08:05 PM   #10
Daves55Sedan
Daves55Sedan's Avatar
As far as I know, the usual repro parts supplier outfits don't offer the metal splash-shield retainer panels for 55/56 full-size cars, but they do sell the rubber splash shields behind the metal panel. I believe they also sell the 3/8" hex-head lag screws for attaching the metal retainer panels to the fender apron, but they are NOT exact duplicate of originals.
Daves55Sedan is offline   Reply With Quote
Old 11-21-2020, 08:05 PM   #11
paul2748
paul2748's Avatar
Early 55-57 Thirds use a similar piece. I don't know if it's the same or different. It's reproduced. Both sides the same. Called Metal Retainer for Apron Seal.
Might want to check with Concour's Parts as they sell both Tbird and sedan parts.
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 11-22-2020, 02:25 AM   #12
KULTULZ
KULTULZ's Avatar
Cool Re: 56 fender apron retainer
Well, we tried. Without an early MPC that showed the 16050 PN, it is difficult to determine much of anything.
Old 11-22-2020, 12:53 PM   #13
56sedandelivery
They are different. Same dimensions but the dimple is offset so it does not line up correct. I guess I could grind off the dimple and adjust it to fit.
