Old 06-03-2019, 02:05 PM   #1
Chris Haynes
Chris Haynes's Avatar
Default Intake for Riley OHV head
After over a decade of sitting on the shelf I finally put my Charlie Yapp Riley head on an engine. It wasn't until I attempted to bolt my Intake manifold on the head that I realized that the spacing of the holes for the studs is narrower that those on the Ford block. Mr Yapp informed me that he no longer makes intakes for his heads. He suggested "Routing out" the manifold to deepen the area in my Webber intake to fit the studs. Measurements show that the studs would be touching the manifold with no room to put nuts and washers on the studs.
I am open to ideas.
TIA
1921 Runabout
1930 Tudor
Early 1930 AA
Speed costs money. How fast do you want to go?
Chris Haynes is offline   Reply With Quote
Old 06-03-2019, 02:21 PM   #2
Y-Blockhead
Y-Blockhead's Avatar
Default Re: Intake for Riley OHV head
Back when on Y-Blocks the header tubes were sometimes too close to install hex bolts in the heads. We used allen head bolts to solve the problem. Just a thought. I have no idea how much room you have.
I guess the next best is to cut the manifold you have and reweld it or custom make a tubular intake.
Old 06-04-2019, 12:22 PM   #3
IronTrap
Id Call Max over at H&H Flatheads. He is a Banger speed parts nut and may have a solution or a lead on one for you. Hope that helps!
-Matt/ITG
Subscribe To Our Early Ford Based YouTube Channel: https://www.youtube.com/irontrapgarage
IronTrap is offline   Reply With Quote
Old 06-04-2019, 02:51 PM   #4
john in illinois
john in illinois's Avatar
You might ask on HAMB. I know there is a guy that fabs banger manifolds and headers,but do not remember name.
John
Welcome each day
john in illinois is offline   Reply With Quote
Old 06-04-2019, 04:15 PM   #5
Chris Haynes
John
Thank you John.
1921 Runabout
1930 Tudor
Early 1930 AA
Old 06-04-2019, 07:28 PM   #6
Will Ziegler in LI NY
Will Ziegler in LI NY's Avatar
The person that fabs intakes and headers is BCCHOPIT. He posts on Fordbarn.
Will Ziegler in LI NY is offline   Reply With Quote
Old 06-04-2019, 07:38 PM   #7
Chris Haynes
Thank you Will
1921 Runabout
1930 Tudor
Early 1930 AA
Old 06-05-2019, 01:56 AM   #8
Dodge
You should be able to make your weber manifold fit with a little machining. Yes you can
open up the holes that go over the studs, then you can use an end mill for nut clearance
if the manifold is thick enough, mine is. I'll look at it on my Yapp head and see what it takes. For clearance I have used Chevy/Small block Ford adjustable roller rocker arm adjusting nuts as they are round at the bottom and a 5/8 hex at the top and are over an inch tall. They may fit without machining the manifold.
Dodge is offline   Reply With Quote
Old 06-05-2019, 08:40 AM   #9
Ray in La Mesa
I believe Charlie makes manifolds to fit his heads.
Ray in La Mesa is offline   Reply With Quote
Old 06-05-2019, 11:08 AM   #10
Bob C
From post #1 "Mr Yapp informed me that he no longer makes intakes for his heads."
Bob
Old 06-05-2019, 12:19 PM   #11
Brian T
Brian T's Avatar
Hi Chris,
This is the guy that does custom headers, I am sure he is still active, last post was January this year.
https://www.fordbarn.com/forum/showthread.php?t=16546
http://waccustoms.com
Nothing can be made foolproof, ---- fools are ingenious bastards.
Brian T is offline   Reply With Quote
Old 06-05-2019, 12:57 PM   #12
California Travieso
Send a message via Yahoo to California Travieso
Chris,
How about Red's Headers http://www.reds-headers.net/
Intake - Model A Riley Super Dual
larger image
$245.00
Port openings 1-1/2" - can be opened to 1-3/4"
Comes with bell crank for throttle linkage.
He was in Thousand Palms in the Coachella Valley but it looks like he moved to Chiriaco Summit east of Indio.
What about Miller Hi-Speed. They are in either Oxnard or Ventura.
There are also a lot of Hot Rod shops that could probably build you something.
David Serrano
California Travieso is offline   Reply With Quote
Old 06-05-2019, 01:28 PM   #13
Charlie Stephens
It has been a long time but I thought the heads were sold with the manifold. Have you looked everywhere?
Charlie Stephens
Old 06-05-2019, 03:36 PM   #14
Chris Haynes
Discontinued along with the heads.
1921 Runabout
1930 Tudor
Early 1930 AA
Old 06-05-2019, 03:38 PM   #15
Chris Haynes
Originally Posted by California Travieso View Post
Chris,
larger image
$245.00
David Serrano
Those are for dual 97's. I want to run the single Webber.
1921 Runabout
1930 Tudor
Early 1930 AA
Old 06-05-2019, 03:39 PM   #16
Chris Haynes
Charlie Stephens
No, They were not.
1921 Runabout
1930 Tudor
Early 1930 AA
Old 06-05-2019, 03:40 PM   #17
Chris Haynes
My manifold is one of the early ones made in CA over a decade ago. It has larger tubes with thin walls so milling would open a hole in the tube.
1921 Runabout
1930 Tudor
Early 1930 AA
Old 06-05-2019, 08:51 PM   #18
Dodge
Hi Chris,
I looked at my Yapp head today along with a weber manifold and see what your talking
about.
My manifold would work with the mounting holes elongated and using the rocker arm
adjusting nuts, or as suggested above you could use a socket head allen bolt.
I'll PM you my email address if you want to send a picture of your manifold.
I'd like to see how close the "tubes"are to the mounting holes.
Dodge
Old 06-06-2019, 01:02 AM   #19
Chris Haynes
I have contacted Bill Carlson and he is making one for me.
1921 Runabout
1930 Tudor
Early 1930 AA
Old 06-06-2019, 04:01 AM   #20
Dodge
Awesome. Show us a picture when you get it.
