Old 02-28-2016, 11:00 AM   #1
jchochole
jchochole's Avatar
Default Are rubber radiator grommets available?
Has anyone found the rubber radiator shell grommets available over the counter at retailers? I am placing an order but wanted to see if I can buy those locally first.
Thanks,
Jim
"Whether you think you can, or think you can't- you're right." H. Ford
jchochole is offline   Reply With Quote
Old 02-28-2016, 11:12 AM   #2
Gary WA
Gary WA's Avatar
Default Re: Are rubber radiator grommets available?
I would say no. You may be able to retrofit something, but I use old pieces of tire tube.Model A Vendors do sell the kits.
www.whidbeymodelaclub.com
Old 02-28-2016, 11:17 AM   #3
jchochole
jchochole's Avatar
Gary- how do you use old tire tubes?
Old 02-28-2016, 11:32 AM   #4
Bob C
Check McMaster-Carr http://www.mcmaster.com/#rubber-grom...hings/=11bmfsi
Bob
Old 02-28-2016, 11:36 AM   #5
jchochole
jchochole's Avatar
Thanks Bob- I know I can always order them but my goal, for this item, is to shop locally. I wish I had a Tractor Supply or McMaster local.
Old 02-28-2016, 11:50 AM   #6
Bob C
Ok then how about Lowes http://www.lowes.com/Search=rubber+g...bber+grommets#!
Bob
Old 02-28-2016, 11:55 AM   #7
jchochole
jchochole's Avatar
Thanks Bob- those look like potential winners!
Old 02-28-2016, 04:11 PM   #8
Gary WA
Gary WA's Avatar
Originally Posted by Bob C View Post
I thought it was for the hold down for radiator! Not grommets. My mistake for the year!
Old 02-28-2016, 06:43 PM   #9
jchochole
jchochole's Avatar
Follow-up, I hit Home Depot and found neoprene grommets for about $2, they fit the headlight holes pretty well!
Old 02-28-2016, 10:45 PM   #10
RHD
RHD's Avatar
I have found that most suppliers sell Radiator grommets in sets of 3 either 28/29 or 30/31. The fit and work well. Try Mikes Affordable.
Over the counter grommets would be doubtful.
R.H.D.
Author of Model 'A' Ford technical manuals.
Supplier of good original RHD parts.
RHD is offline   Reply With Quote
Old 02-29-2016, 08:56 AM   #11
Merc Cruzer
Merc Cruzer's Avatar
Ace Harware
Merc Cruzer is offline   Reply With Quote
