04-26-2020, 08:09 PM | #1 |
Distributor for a 8BA
Currently building an 8BA bored .040 over, with Max 1 cam, two deuces, headers to go in my '40. Trying to figure out what distributor to go with, as what I have read on here, the stock one won't cut it.
04-26-2020, 08:51 PM | #2 |
Re: Distributor for a 8BA
The converted Chevy ones work well. Several members here on the Barn convert them. Babba is one as is Charlie NY. And maybe Third Generation.
04-26-2020, 08:56 PM | #3 |
Buba and charlieny are were the 2 premiere guys to convert a Chevy distributor for a flathead. Buba is no longer doing them due to health issues. That leaves charlieny and his reputation is spot on. He is in the process of doing a run of conversions right now. If it were me I'd get in touch with him and get one on order. Of course there are other options and opinions.
04-26-2020, 09:52 PM | #4 |
If having a SBC distributor converted, consider a "flattop" Mallory. They are still available for a reasonable price (on eBay even), work well, and look good!
(When you can't make 400 HP these days, the only alternative is looking good.) |
04-27-2020, 07:36 AM | #5 |
Thanks for all the replies. I'm going to check with Charleyny about his timeline. Also was wondering if anyone has used the new Mallory distributor offered by Speedway or Summit. I guess the Pertronix conversion is a bust too ?
04-27-2020, 08:08 AM | #6 |
04-27-2020, 08:47 AM | #7 | |
That being said, I haven't used one for several years, so who knows what's been coming out of China lately. |
04-27-2020, 09:08 AM | #8 |
I have stopped doing the chevrolet conversion , sold everything delco to charlie will still do helmets and crabs later i hope as health improves ..
Info here http://www.bubbasignition.com/loadam...lacements.html |
04-27-2020, 09:59 AM | #9 |
There is only one reason to replace the stock original distributor. Modifying the intake system. The original in proper working order works quite well on both 5 and 12 v. And a petronics conversion will nly replace the points.
When changing the intake system, including a camshaft, the original distributor cannot provide the proper advance curves under all load conditions. The converted SBC distributer, weather with a points or electronic output, can be taylored to your needs. |
04-27-2020, 11:03 PM | #10 |
Taylored how Ron?
According to the factory manual I found it says maximum advance is 11 degrees!? Is that enough advance? 11 degrees? When I screen the 8 RT. In my pickup that’s just what the max comes to 11 degrees. |
04-28-2020, 05:34 AM | #11 | |
22 degrees advance and is a good spec to go by . |
04-28-2020, 06:22 AM | #12 |
A talored ignition advance, is one that meete the requirements of the engine under various load conditions. For example, under hard acceleration, you only need 18/20 degs advance. However, in cruse, you might need 28 degs. It also depends on the modifications you've made to the engine. Is it stock, or a 294 bullet. Or something in between. The only distributor on tee market today that meets these requirements is: the SBC distributor, with adjustable Mechinacle and Vacuum advance. It also doesn't matter if it's got points or electronic coil control.
04-28-2020, 08:21 AM | #13 |
Any mechanical advance system is by nature a compromise. Some are better than others. A truly tailored system would be computer driven.
04-29-2020, 03:33 PM | #14 |
The trick is to find exactly how much advance at what RPM and load is right! After all, "garbage in equals garbage out!" So someone would need to spend a whole lot of dyno time plotting the correct timing "map". I doubt any existing aftermarket software would work, even "self-learning" ones.
04-28-2020, 02:33 PM | #15 |
Thanks Ron. I really appreciate your post. I like my stock distributor better now.
I meant to write,”when I screem the engine”. With timing light on it at high RPMs the timing reads about 11 degreees Before Top Dead Center. I got a new advance unit at NAPA In 2015. I got a post from Bubba that says the 11 degrees means 11 distributor degrees. But even with a vacuum pump on the advance unit I only get about 11 or 12 on the crank pulley. I advanced it about 5 degrees and it has good power at speed gets 10 miles per gallon empty. I’m gonna consider getting a distributor from Bubba. |
04-28-2020, 04:09 PM | #16 |
Somethings sure is not correct, but at least your getting into the 16-17 degree range. Could be the distributor advance or it could be an issue with the carburetor vacuum source. Converted distributor or rebuilt original would sure be an improvement.
04-28-2020, 05:38 PM | #17 |
If you are running 2 carbs with a stock loadomatic distributor on your set up you probably will not get an difference in advance as loadomatic isvaccum advance only.
Need the Chev type set up with mechanical and vaccum advance. Phil NZ Last edited by Phil Gillespie; 04-28-2020 at 06:48 PM. |
04-28-2020, 06:44 PM | #18 |
Phil, Loadomatic is vacuum advance only, no mechanical advance. I just noticed the two carbs, very unlikely the loadomatic is working correctly with this setup. What is the vacuum source? What carbs are being used?
04-28-2020, 06:50 PM | #19 | |
My oversight.Wrong info not productive. Phil NZ |
04-28-2020, 09:58 PM | #20 |
Yes a computer system is best, But??????
