Old 06-03-2010, 08:46 PM   #1
jaguar6165
Default Zmax?
Can you use zmax in a model a. I know it's supposed to be absorbed by engines and the a engine is very porous. Would it work? Has anyone tried it?
jaguar6165 is offline   Reply With Quote
Old 06-04-2010, 07:47 AM   #2
Aerocraft
Aerocraft's Avatar
Default Re: Zmax?
I have never heard of that product. Do you have a link to a product description?
Aerocraft is offline   Reply With Quote
Old 06-04-2010, 07:50 AM   #3
Buz
Buz's Avatar
Default Re: Zmax?
Clean and proper weight motor oil will do a better job than any of those additives. I don't believe half the claims they make.
Buz is offline   Reply With Quote
Old 06-04-2010, 07:55 AM   #4
Ron/IA
Default Re: Zmax?
zMax is a brand name, and they make several aditives for fuel and oil. I have seen it advertized by Carrol Shellby on TV. Just Google "zmax" and you can learn all about it.
That is an interesting question if zMax would be a benefit to the Model a engine. I personally use toady's modern detergent oil in my A engine, the oil and their additives (IMHO) are better refined than those from the early party of the 20th century. Maybe we will see some infor from a zMax user.
Ron/IA
1929 Fordor Steelback
Hawk A Model A Ford Club
http://hawkamodelaclub.org/
Ron/IA is offline   Reply With Quote
Old 06-04-2010, 10:33 AM   #5
roccaas
roccaas's Avatar
Default Re: Zmax?
I put some in at the last oil change to get some Zinc into the mixture. It would take a carefully controlled trial to determine if it really helps. There is a company making a Zinc heavy oil (can't remember who) that claim the additives are a waste, and you need the Zinc rich oil.
roccaas is offline   Reply With Quote
Old 06-04-2010, 10:40 AM   #6
V4F
V4F's Avatar
Default Re: Zmax?
i use valvoline VR1 , as my research showed me it was about the only oil with ZDDP in it ................... steve
V4f
V4F is offline   Reply With Quote
Old 06-04-2010, 11:03 AM   #7
Doug Cox
Doug Cox's Avatar
Default Re: Zmax?
My only thought is; comparing today’s modern high RPM engines with the Model A engine is a real stretch. Much lower compression, much, much lower RPMs.
With that said, what great benefit would it achieve by adding very expensive oil additive to a Model A engine? I prefer to spend my $$ and use a top quality lubricant and be vigilant about changing the oil. I might add, I do not use an oil filter.
My bottom line is I subscribe to the K.I.S.S. principle of keep it simple. Therefore one may do as he things best but the Cost/Benefit of ZMax doesn’t add up in a Model A , (IMHO)
Doug Cox is offline   Reply With Quote
