Old 09-17-2020, 06:16 PM   #1
Conaway2
Conaway2's Avatar
Default Axle shims
Where can I find rear axle shims thinner than 0.010” ? One shim is not enough and 2 is too much....
Thanks - JIm
Conaway2 is offline   Reply With Quote
Old 09-17-2020, 07:29 PM   #2
katy
katy's Avatar
Default Re: Axle shims
Make your own. Here's a pattern, but you'll have to adjust the size:
You could also make one .015".
Old 09-17-2020, 07:59 PM   #3
kenparker0703
juz so u kno. Alumninum Beer can, soda pop can all are .0035 thick make good shim material.
kenparker0703 is offline   Reply With Quote
Old 09-17-2020, 08:06 PM   #4
Conaway2
Conaway2's Avatar
Good to know ! Thanks for your responses. I’ll empty a beer can tomorrow to get the metal.....
Jim
Old 09-17-2020, 08:50 PM   #5
GRutter
GRutter's Avatar
Sacrificial Beer. I like it
GRutter is offline   Reply With Quote
Old 09-18-2020, 07:36 PM   #6
ursus
The working life of an aluminum shim in such a critical area will be sadly short.
ursus is offline   Reply With Quote
Old 09-18-2020, 08:37 PM   #7
Conaway2
Conaway2's Avatar
I found a Model T .005” stainless steel shim that seems to do the trick in combination with the 0.010” shim already installed. Never thought of looking at Model T shims, but they fit a Model A axle quite well.
