Old 09-16-2020, 08:06 PM   #1
Daba
Default Exhaust manifold for model B engine
Exhaust manifold for model B engine?
Does anybody know if a 30-31 model a exhaust manifold will fit on a model B motor? Mine is almost split in half I may need to get it welded or find a new one. Thanks again Daba
Daba is offline   Reply With Quote
Old 09-16-2020, 08:37 PM   #2
Charlie Stephens
Default Re: Exhaust manifold for model B engine
The Model B exhaust manifold will bolt right on to a Model A motor. The problem comes from the fact that the Model B manifold exhaust pipe goes down at about 45 degrees while the Model A goes straight down. What vehicle do you have?
Charlie Stephens
Old 09-16-2020, 10:27 PM   #3
CWPASADENA
CWPASADENA's Avatar
Are you looking for an exhaust manifold for a Model B engine installed in a Model A chassis or a Model B engine installed in a '32 chassis, or a Model B engine in a 33-34 chassis?
If in a Model A Chassis, use a Model A Manifold which are available new.
If in a '32 chassis, only a '32 Model B manifold will work. These are not available new but if you need one, I have a good used one.
If it is in a 33-34 Chassis, use a Model A manifold, they are the same as '33-'34.
Chris W.
CWPASADENA is offline   Reply With Quote
Old 09-17-2020, 06:38 AM   #4
Daba
I have a Model 31 A with a model B engine the exhaust manifold is cracked pretty good around cylinder three, I may try to get it welded today just wondering if a Model A would fit as I believe that’s what’s in there. Thanks again
Old 09-17-2020, 06:47 AM   #5
jetmek
They are interchangeable except for the outlet angle. Id advise against trying to weld it. I probably have several if you care to trek to albany. Or check with tams for a used one
engine and component overhauls my specialty!
Website- www.godevilgarage.com
jetmek is offline   Reply With Quote
Old 09-17-2020, 10:37 AM   #6
Bob Bidonde
Bob Bidonde's Avatar
A Model "A" exhaust manifold fits onto a Model "B" engine without any modifications, and it installs in same way it did on the Model "A." The photo is of the Model "B" engine in my 190A. However, if you have a 1932 - 1934 Ford, the exhaust pipes will not fit-up to the Model "A" exhaust manifold. The exhaust pipe (AKA muffler assembly) must be of a Model "A."
File Type: jpg 190A Model B Engine Installation 416kb.jpg (86.0 KB, 29 views)
Bob Bidonde
Old 09-17-2020, 10:53 AM   #7
Big hammer
I wouldn't waste your time trying to weld it, new or used manifolds are inexpensive! If you're just wanting to weld for practice, have fun
get a bigger hammer tap done
