09-15-2020, 03:53 PM | #21 | |
Re: Wisdom of Stopping Engine by Choking It Out
09-15-2020, 04:03 PM | #22 |
Lots of armchair opinions within, and yet these cars have managed to survive 90 years with all sorts of abuse and neglect.
Choking the engine to kill it will do absolutely no harm to the engine, maybe the plugs overtime. We're talking about such a minimal amount of fuel that is transmitted in a near vapor form. And from maybe 800 rpm to 0 in a matter of seconds. If you were so concerned, you wouldn't choke the engine to start it, and you'd kill the fuel, to stop the engine. Turning off the ignition just takes away the spark, it still allows fuel into the cylinders without burning. |
09-15-2020, 05:07 PM | #23 | |
I never mentioned rust, my concern was dry cylinders. And where is the gas going to evaporate to in a cylinder with the valves closed? i think I will continue to let the carburetor run dry.
Ruth "Sometimes you really DO need to read the whole thread" |
09-15-2020, 08:33 PM | #24 |
If you choke it, you are cutting off its air supply.
09-16-2020, 08:46 AM | #25 | |
I am not necessarily disputing or disagreeing with you on the 'restart' assistance. I agree you never mentioned rust however I have looked at many cylinders doing inspections and they tend to rust, -even when the valve appear to be seated. This would tend to indicate there is a lack of oil there anyway. The skirts when cold have not expanded enough to create friction like they would when the engine is running. By the time an A engine has started, the rods have splashed enough oil where it is no longer an issue for the lower cylinder walls. As far as where the evaporated fuel goes, my theory is it goes to the same place as where the compression goes when an engine is stopped. It slowly escapes past the ring gaps. |
09-16-2020, 10:52 AM | #26 |
09-17-2020, 09:34 AM | #27 |
Re: Wisdom of Stopping Engine by Choking It Out - speaking of KICKING TIRES
delete
09-17-2020, 10:09 AM | #28 |
Another point to ponder: In the days of carburetors it was common to find excessive cylinder wall wear at the top, to the extent that a ridge reamer was standard equipment in every mechanic's toolbox. This ridge was often in evidence before 100,000 miles. Now you will see the factory hone crosshatch clear to the top of the cylinders after 300,000 miles-no ridge! I think fuel injection has a lot to do with this. With a carburetor, a choke was needed for cold starts, resulting in a lot of raw gas (liquid fuel does not burn) washing down the cylinders, causing excess wear. With electronic injection, fuel is atomized at approx. 50 psi. The computer richens the mixture, but the air is not choked off so the cylinders are not washed down.
09-17-2020, 10:58 AM | #29 |
Methinks that a lot of the longevity of modern engines is in the use of superior metals in the construction.
09-17-2020, 05:16 PM | #30 |
Yes very true about superior metals and machining, -and add synthetic oils to the reason for better longevity too, ...not so much on the fuel injection.
09-17-2020, 11:33 PM | #31 |
Right or wrong I turn off the gas cock and let it burn up the fuel.
Keeps the fumes down a bit in the garage.
I love a girl and "Ruby" is her name, ChaCha |
09-18-2020, 10:13 AM | #32 | |
Yup, my father used to do the same thing. He felt it made it easier to restart with a charge of gas in the cylinders. But he stopped doing that when they started putting smog crap on the engines in the early '70s. They were prone to dieseling after switching off the ignition, and goosing it before shutting it off just made it worse. |
09-18-2020, 10:27 AM | #33 |
I don't have much of an issue with shutting down by choking, but, I have to ask why.
That doesn't make sense to me. On a cold start the choke is pulled anyway, so why pull it twice. To shut the engine down I give a twist to the key, its easier. |
