Old 09-11-2020, 07:57 PM   #1
Cpuckett
Default 31 model a gas sediment bowl?
Anyone have a diagram on how the insides of the bowl goes? I’ve tried a rubber and/or cork gasket first, then the filter with spring and the just tried a rubber gasket and screen but every time I tighten it up it leaks. A couple times I tightened it up to much and it quit leaked but the gas quit coming out but I could loosen it and it ran but leaked. Confused 🤷www.jalopyjournal.net♂️
Cpuckett is offline   Reply With Quote
Old 09-11-2020, 10:32 PM   #2
Kurt in NJ
Kurt in NJ's Avatar
Default Re: 31 model a gas sediment bowl?
Which bowl do you have, 3 choices, there is one with glass bowl, one with all cast iron, both of these on the firewall, and in late 31 one on the carb ----
Old 09-11-2020, 11:09 PM   #3
Cpuckett
Glass bowl on firewall
Old 09-12-2020, 10:10 AM   #4
katy
katy's Avatar
This help?
Old 09-12-2020, 10:24 AM   #5
Ernie Vitucci
Good Morning...You might wish to check to see if your gas cap has clogged up...or your fuel line from the tank to the filter has some foreign material in it...Ernie in Arizona
Ernie Vitucci is offline   Reply With Quote
Old 09-12-2020, 12:12 PM   #6
Patrick L.
Patrick L.'s Avatar
Try putting it on loosely and spin/turn the bowl as you do, open the petcock and spin the bowl while tightening it as it fills.
Old 09-12-2020, 01:42 PM   #7
Purdy Swoft
Purdy Swoft's Avatar
I agree with Ernie in post number 5 . The gas cap probably isn't venting . As for the leak ,The thick paper gasket always worked best for me with the glass bowl . Besides the look , the cast iron bulb is my favorite because it uses a lead gasket that works well and doesn't need replacement as often .
Old 09-12-2020, 05:30 PM   #8
Cpuckett
No problems there
Old 09-12-2020, 05:32 PM   #9
Cpuckett
Originally Posted by katy View Post
This help?
What’s the two middle pieces? Gasket then the screen?
Old 09-12-2020, 05:45 PM   #10
Cpuckett
The bowl has no threads
