Old 09-17-2020, 10:01 AM   #41
77Birdman
Default Re: Garage lights
A 4ft LED fixture is pretty cheap. I bought a 10 pack and they ended up costing $14. per light. Much easier taking an old light down and putting up a new one. Nothing needed re-wired. I saw some 4ft shop lights at wallmart that even had a bluetooth speaker in them. Now those were pricey at about $25 ea. and I would have my doubts about the sound quality, but it seems like a good idea. My shop radio will do the job for now just fine.
77Birdman is offline   Reply With Quote
Old 09-17-2020, 10:03 AM   #42
katy
katy's Avatar
If a generator is cheap, in all likelihood it has a "modified sine wave" inverter,
Not all generators have an inverter. Some just put out 60 hz at rated speed. The problem w/them is that the frequency varies w/the speed of the generator. Most are rated at 3600 RPM which equates to 60 Hz. They use a mechanical governor which has "droop". At no load they run a bit fast so the frequency is a bit high, at load they run a bit slow so the frequency is a bit low.
Old 09-18-2020, 02:39 AM   #43
Brad in Germany
Brad in Germany's Avatar
This new LED Hexagon Garage Lighting will light up your garage for sure:
Brad in Maryland
Brad in Germany is offline   Reply With Quote
Old 09-18-2020, 07:28 AM   #44
77Birdman
Nice looking service bay!
Old 09-18-2020, 08:27 AM   #45
BillLee/Chandler, TX
BillLee/Chandler, TX's Avatar
That type would have to fall into the "cheap" category. May be producing PSW but with unreliable frequency.... yuck!
Bill Lee
http://www.CedarCreekAs.org
BillLee/Chandler, TX is offline   Reply With Quote
Thread Tools
Display Modes
