05-16-2010, 10:42 PM | #1 |
Questions on tail/stop/turn signal light colors
I have installed a complete new wiring bundle which included the turn signal option. I also installed aftermarket lights. The tail light is red, the stop lights are the amber and the turn signal lights are amber. Did I hook them up correctly or should they be different?
Thanks for the info.
Fred Kroon 1929 Std Coupe 1929 Huckster |
05-17-2010, 09:14 AM | #2 |
Re: Questions on tail/stop/turn signal light colors
mine are the same . the new cars made it ok to run amber for stop/turn ...... steve
V4f |
05-19-2010, 12:29 PM | #3 |
Group,
Could someone let me know when the change to "amber" for stop lights happened ? I'm wired for top/amber for stopping and bottom/red for lights. I always thought that that was backwards ? Marc |
05-19-2010, 12:59 PM | #4 |
I converted my amber brake light to red, using an ALL RED taillite lens since I figure its easier to conform to the world then to confuse drivers behind me.
I have never seen an amber brake light on a modern car. This way, my taillite, brake light, directionals, and third brakelight LED all conform to what following cars are expecting to see. |
05-19-2010, 01:39 PM | #5 |
A 1960 BMW 507 has amber stop lights and red turn signals, so it would have been after that.
Steve |
05-19-2010, 01:40 PM | #6 |
05-19-2010, 02:08 PM | #7 |
Art - from where did you get your taillights? How were they to install?
Did you have to do anything special to get them to work with the turn signal switch? Steve |
05-19-2010, 02:33 PM | #8 |
The bottom light is the driving light, stop is on top. The change from all red lenses to amber on the top is generally considered a 1929 to 1930 model year change. I use LED lights which are red and turn the amber to red when lit.
05-19-2010, 05:30 PM | #9 |
My 1930 Packard has a red taillight and amber brake light. The inspection station (Texas) had to look it up in a reference book to establish that it was correct.
European cars started the amber color much more recently but they had a separate turn signal light whereas American cars used the same bulb for stop and turn. |
05-19-2010, 06:03 PM | #10 | |
05-19-2010, 06:51 PM | #11 |
Thanks guys for all the ideas and the way your rigs are set up. I think I will leave mine the way it is for now and maybe get a LED light to put up in the center of the back. Maybe someday I will change the glass to all red.
Thanks again for the comments
05-19-2010, 07:05 PM | #12 |
I think I bought the tail lights from Bratton's, they were about $55.each and I bought the entire tail light. I used a switch that I drove from the spark advance lever ( Mallory dizzy) and used the park lights (put in brighter bulbs) in the headlights for the fronts. I used a $5 6v flasher from NAPA.
They work fine except for one problem, I can't find a buzzer loud enough to tell me when the signals are on...anyone have any ideas? I tried Radio Shack but what they stock is not loud enough for my old ears. |
05-19-2010, 09:24 PM | #13 | |
Know what you mean, See if you can find something called a "Sonalert". They are loud, piercing sound devices. Not a buzzer, but it will get your attention. I think this one is the same type of device: http://www.radioshack.com/product/in...ductId=2062395 75 db. Should be enough to get over the sound of an A. And it's even 6 volts! You could also get a relay and just wire it up so that the power runs through the normally-closed side of the relay. That will turn it into a buzzer. Steve |
05-19-2010, 10:40 PM | #14 |
I tried a 90db and it wasn't loud enough. By the way, I remember that I purchased the tail lights from Speedway at a sale in December. They were about $50. for the pair. Their latest catalog shows them at $80 the pair or $50 for just the inserts.
05-19-2010, 10:49 PM | #15 |
I bought a Snyders buzzer and it was on the quiet side, so I bought a Radio Shack buzzer and cars next to me can hear it. I am not sure of the dbs, but it cost only about $5.
05-20-2010, 01:07 AM | #16 |
I also use the Radio Shack buzzer and it is very loud. you can get them in 6V or 12V
05-20-2010, 06:23 AM | #17 |
Banned
That's just like mine. Red for tail and amber for stop
skip. |
05-20-2010, 09:42 AM | #18 |
[QUOTE=john hamilton;11043]My 1930 Packard has a red taillight and amber brake light. The inspection station (Texas) had to look it up in a reference book to establish that it was correct.
Was the standard Model A light Amber for Stop and Red for Tailight in 1930's ? Marc |
05-20-2010, 06:42 PM | #19 |
Yes.
Jim Cannon Former MAFCA Technical Director "Have a Model A day!" |
05-20-2010, 07:35 PM | #20 | |
the average goober behind you has no clue what that yellow light is all about. |
