01-18-2015, 10:21 AM | #1 |
Wrap Tools – No Scratch
Two questions, with the first being the most important to me:
1. What are some of the modifications made to your tools to prevent them from scratching your car? 2. Are their certain areas of the vehicle being worked on where you feel that a modification of a tool is required else you are almost guaranteed to scratch it? Thanks, Paul
http://MODELABASICS.com/ How Things Work on a Model "A" Ford Fordbarners, Feel free to use the pictures on my site to answer questions and create tutorials/tech articles. |
01-18-2015, 01:48 PM | #2 |
Re: Wrap Tools – No Scratch
Personally, we do not use anything more than quality tools, ....most of which are hand tools used to assemble the cars we work on. In most circumstances, I can guarantee you that we DO scratch each and every vehicle we restore during the assembly process. In all scenarios, we are able to easily touch-up any scratch or chip where it is undetectable. I think you are over-worrying about this.
01-18-2015, 03:22 PM | #3 |
I was at a National V8 Meet, several years ago, and a fellow had to take off a water pump, but had no tools. My buddy took over some tools and the guy looked at them and DEMANDED 6 point wrenches. My friend, just quitely, gathered up his tools and took them back to his car.
MIKE (mikeburch) |
01-18-2015, 04:18 PM | #4 | |
01-18-2015, 04:59 PM | #5 |
In answer to 30ccpickup question:
I have just had my wheels powder coated and did not want to scratch them in any way so.... my 1/2" drive extension and the socket I use both have plastic tubing covering each. |
01-18-2015, 07:00 PM | #6 |
W. Michael |
01-18-2015, 07:11 PM | #7 |
when installing pre- painted screws put masking tape on the screw driver blade to prevent it from chipping
01-18-2015, 07:11 PM | #8 |
A Car WITHOUT a scratch is not authentic ! The FORD FACTORY produced them that way, and so should you. For REAL authenticity, make sure your restoration has a scratch (or two, or three).
01-19-2015, 06:45 AM | #9 |
No car deserves a scratch when caution can be taken. Especial yours when I am helping out with it. Members are asking for help with their cars, and I don't, want to put on the 1st scratch since new paint. I can't touch it up and hide it like the factory could. I would not buy a new car with a scratch. I would point it out and make them fix it! I am just a friend, they would be stuck with it.
01-19-2015, 07:10 AM | #10 |
01-19-2015, 07:41 AM | #11 | |
a nick or scratch can be successfully repaired if you have the proper touch up paint, then building up the area little by little with paint till its level with the outside edges. this takes time to let each coat dry::::: then polish the area ask me how i know... as brent mentioned assembling a car its impossible to not have issues. of course your eye may always see something because you know what happen but no one else will notice anything |
01-19-2015, 09:54 PM | #12 |
As Brent and Mitch said , it is just part of the process, be carefully, wise, And prudent when assembling are the best guides
I have used electrical tape at times for a cushion on some fasteners if space permits. Always make sure you get them tight. There are pliers out there with soft protective jaws I always do a couple if rounds of touch up . When doing heavy engine work I use multiple furniture blankets over fenders and take every precaucious measure I can If something happens and it will at some point you just fix it As Mitch said you do a good touch up job and no one will know Larry |
01-19-2015, 10:09 PM | #13 |
I was helping an old gent reassemble a 1931 Victoria and before he was ready to drop the body on his glistening chassis he grabbed a ball pean hammer and gave that frame a whack. I asked him why he did that and he told me that there were two reasons... 1st was to get it out of the way by deliberately damaging the finish in an inconspicuous spot so that you'll not accidentally scratch it in an obvious spot.
2nd reason was that nothing must be construed as "perfect" because only God is perfect! |
01-20-2015, 01:08 AM | #14 | |
Only my lug wrenches have tape on them.
01-20-2015, 03:14 AM | #15 |
A few years back I help with the restoration of a Mustang a 100% bare metal resto
when I saw it painted I spotted a paint run in the engine bay pointed it out to the painter Who told me that took 3 goes to get right and was meant to be there I said what the F--- he then showed me the judging guide book and yes it is meant to have the run Needless to say while correct it is over the top IMO |
01-20-2015, 04:39 AM | #16 | |
01-20-2015, 01:13 PM | #17 |
1921 Runabout 1930 Tudor Early 1930 AA Speed costs money. How fast do you want to go? |
01-20-2015, 01:27 PM | #18 |
look they have a loaded rear spring not installed in the body..
dont they know thats a no no.... i hope OSHA does not walk in Last edited by Mitch//pa; 01-20-2015 at 01:44 PM. |
01-20-2015, 02:17 PM | #19 |
I'd like to know how the rear spring was attached, in that, to the crossmember or the axle first.
I think I know, but,,,,,, |
