Old 10-13-2013, 11:09 AM   #1
spdway1
spdway1's Avatar
Thumbs down !! Sparks !!
When I attempt to start my AA, the foot pedal rod sparks really bad on the hole where it goes threw the firewall.
What do I need to do to correct this?
Thank you
spdway1 is offline   Reply With Quote
Old 10-13-2013, 11:13 AM   #2
nhusa
nhusa's Avatar
Default Re: !! Sparks !!
Only if you plan on pouring gasoline on the floor
nhusa is offline   Reply With Quote
Old 10-13-2013, 11:36 AM   #3
jmeckel
jmeckel's Avatar
It also could be you have a poor ground. Start with cleaning the ground connections, also use a jumper cable and run it from the battery ground to the starter bolts or any place on the engine you can get to that you can get a good solid clamp on. If this fixes the issue than you need to go through all the frame to engine to body ground points and clean them up, including engine pans. Another option is to run a #2 or larger soft copper cable from the engine (I attached to one of the starter to engine mounting bolts) to the battery ground cable to frame bolt. Again make sure there is no rust, paint, dirt..... etc. at the connection points and that they are tight.
Jon
"If you choose to not decide, you still have made a choice!" RUSH
Don't tell me what you know..... Tell me what you have done.
jmeckel is offline   Reply With Quote
Old 10-13-2013, 11:40 AM   #4
Mitch//pa
agree with #3 # 4 's advice
Old 10-13-2013, 12:36 PM   #5
PC/SR
There is a short circuit, probably the switch insulator per #3, but do #4 too for good maintenance, plus check the "hot" battery cable to the starter while you are at it to be sure it is not touching anything.
PC/SR is offline   Reply With Quote
Old 10-13-2013, 12:42 PM   #6
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
On this subject: Who supplies the BEST repro starter switch, or are they all from the same source? Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 10-13-2013, 12:42 PM   #7
Jim Brierley
Do the above, then slip a short piece of fuel hose over the stem of the rod.
Old 10-13-2013, 12:52 PM   #8
Charlie Stephens
Sounds like a good idea. That will move the problem to the choke rod will it will not be as annoying. On the other hand, maybe you could fix the problem before it causes a disaster (if it is a short in the switch). I vote for the ground being the problem.
Charlie Stephens
Old 10-13-2013, 03:38 PM   #9
1931 flamingo
1931 flamingo's Avatar
Is there not supposed to be a grommet around the rod where it passes thru the firewall/floorboard??
Paul in CT
Old 10-13-2013, 03:51 PM   #10
Ross/Kzoo
Ross/Kzoo's Avatar
On important electrical connections like battery and starter I like to use Alnox.
http://www.aflglobal.com/Products/Co...-Compound.aspx
If I were to describe it I would say that it's greasy with small metal shavings in it.
Ross/Kzoo is offline   Reply With Quote
Old 10-13-2013, 07:17 PM   #11
Purdy Swoft
Purdy Swoft's Avatar
There should be a bakelite or rubber starter switch rod grommet in the firewall.
Old 10-13-2013, 07:33 PM   #12
spdway1
spdway1's Avatar
I put some wraps of Duct tape on the pedal shaft for now. I will change the switch out too.
This is another AA project new to me.
Old 10-14-2013, 12:29 AM   #13
tbirdtbird
can someone enlighten me as to the point of post #2
'31 180A
tbirdtbird is offline   Reply With Quote
Old 10-14-2013, 12:44 AM   #14
Tom Wesenberg
Tom Wesenberg's Avatar
I was wondering the same thing? By checking the edit time in #1 I guess something got removed.
Old 10-14-2013, 06:01 AM   #15
nhusa
nhusa's Avatar
Me too. When I reread #1 - #2 did not make sense, but then I remembered that post #1 originally said something about it was sparking and should he do something about it.
The question as originally stated was rediculous so I figured that it was a spoof and answered with the gasoline comment.
If I had said -of course you need to fix it - it still would not make sense because the question was changed to what should I do
Old 10-14-2013, 06:40 AM   #16
CountrySquire55
CountrySquire55's Avatar
Might be that the starter rod has come loose from the shaft that connects it to the starter switch. The nut on the rod, on my car anyway, sometimes vibrates loose and allows the rod to turn out of the shaft. If this happens, and the starter button is pressed, the rod can come in contact directly with the switch connections on the starter itself and cause the sparking.
CountrySquire55 is offline   Reply With Quote
Old 10-14-2013, 06:50 AM   #17
Patrick L.
Patrick L.'s Avatar
Just make sure there are no wrinkles in the tape. The number of wrinkles determine the quality of the repair.
Old 10-14-2013, 07:38 AM   #18
Keith True
Keith True's Avatar
Insulation really isn't the answer.There should be NO juice in that rod,at any time.You have something wrong in the switch,and at some point,things will be melting.There was a fiber plunger in the switch,that is either damaged or has been replaced with a wrong material.
Old 10-14-2013, 10:19 AM   #19
Tom Wesenberg
My first thought was exactly the same as Keith's, but then when someone mentioned a poor ground, that also is possible. One end of the rod touches the switch housing and the other end touches the firewall, so if the starter has a poor ground then when the starter demands 100 amps sparks could fly from the rod where it touches the firewall, and provides another ground path.
To check for a poor electrical path just connect the meter leads to the points in question and see if any voltage is shown. 0 volts would mean you have a good connection. So, connect one meter lead (-) to the starter switch housing and the other meter lead (+) to the firewall, then push the starter switch and hope to read 0 volts. Set the meter on the lowest DC volts setting.
It's also easy to remove the switch and inspect the two insulating parts inside that Keith mentioned. I often find the thick t part at the end of the rod is worn and can short.
Old 10-14-2013, 10:46 AM   #20
Purdy Swoft
I agree with jmeckle and Tom. Not trying to be disagreeable but poor ground will cause this problem and it will only happen when the starter is in use. I never was much into test meters. I like the way that jmeckle describes how to test the problem in post number 4. Some don't have test meters.
I think that the guy in post number 2 meant that if there was gas in the floor that sparks from the starter switch rod could cause a fire. Its not likely that anybody would pour gasoline in the floor unless it was accidently.
