09-30-2012, 04:12 PM | #11 | |
Re: Is There An Electrician In The House?
Joey If there is no voltage on the armature side of the generator when the engine is running, than the generator is not putting out when the engine is running. You did not paint the generator after it was tested and there is not a ground for the generator.That darn paint is a good insulator when you do not want it to insulate and is not a good insulator when you need a little luck. I am still waiting for Ford Garage to reply about voltage at the cutout. I could be 180 degrees off on this stuff.
IF IT CAN NOT BE FIXED WITH BLASTING WIRE, JB WELD OR DUCT TAPE ---IT CAN NOT BE FIXED Do not get me started on the stupidity of ethanol. I think one of the monitors is from Iowa and he will delete the thread. |
