Old 09-04-2020, 06:33 PM   #1
legacy
legacy's Avatar
Default Rattling noise while driving
I just got a 1928 Model A with a multi disk clutch. I don't have any experience with a Model A.
I was driving the car and something started rattling, it got worse if I pushed in the clutch pedal.
I removed the inspection panel on top of the bell housing., there is a disk that is right ahead of the throw out bearing. That disk is loose and I can spin it on the shaft. That's what is causing the rattling.
What am I looking at here and what do I need to do to fix this.
Thanks
legacy is offline   Reply With Quote
Old 09-04-2020, 07:16 PM   #2
Mulletwagon
Mulletwagon's Avatar
Default Re: Rattling noise while driving
Look close and try to determine if your throw out bearing has separated. May need a throw out bearing change. If so, need to pull back the rear axle and drop the trans to remove the bearing. Interesting caper, let us know what you determine.
Mulletwagon is offline   Reply With Quote
Old 09-04-2020, 09:46 PM   #3
GRutter
GRutter's Avatar
The Multi Disc clutch can be noisy. That clutch is unique to the early 28 models only and was replaced with the single disc clutch in late 28.
The clutch consists of multiple driven lined discs with "teeth" that fit into the flywheel, and alternating unlined discs that are splined to a center hub. They discs can become noisy as the teeth wear and "rattle" in the flywheel.
As far as I am aware, reproduction discs (lined and unlined) as well as the throwout bearing for the multidisc clutch are not available. Keep an eye out for these parts or place an ad here for them. Parts are available and sometimes you may need to find several clutch packs to get enough good discs. The discs can be relined, but you need discs with good teeth. Once rebuilt, a multidisc clutch will give good service.
Replacing the multidisc clutch with the later single disc clutch is also possible, but not easy. The flywheel, clutch, bell housing, transmission and pedals are different. But later model parts may be easier to find and reproduction clutch discs and bearings are available.
GRutter is offline   Reply With Quote
Old 09-04-2020, 10:26 PM   #4
Chuck Sea/Tac
Chuck Sea/Tac's Avatar
Pictures would be very helpful
Old 09-05-2020, 04:32 AM   #5
legacy
legacy's Avatar
Thank you all for the information. I am going to take it all apart and have a look.
I'll let you know what I find.
I can't take any pictures yet, all I have open is the inspiration plate on top of the bell housing. Byt by reaching in there, I can touch what feels like a round cover of some sort and I can just turn it on the shaft.
Old 09-06-2020, 07:17 PM   #6
legacy
legacy's Avatar
After some more searching, I found out that my 1928 Model A has a 1935-42 V8 Ford 09A-7563 pressure plate.
The pressure plate installed in this car is very different from what I expected to see.
Anyway, there is a thin plate within the pressure plate assembly that is loose and rattling around.
Old 09-06-2020, 10:47 PM   #7
GRutter
GRutter's Avatar
It appears then that you must not have an early 28, or somewhere during it's history, the flywheel, bellhousing, and transmission were changed. Also changing to the V8 pressure plate is a pretty common modification.
The only "plate" within the pressure plate assy should be part of the clutch disc... the plate that is riveted to the disc and part of the spring retention.
Please attach a picture of what you're seeing.
Old 09-07-2020, 09:52 AM   #8
legacy
legacy's Avatar
Going by the serial number stamped on the engine, this car was built in mid December 1928.
It should have a multi disk clutch, I checked with the previous owner and he says that it's a multi disk clutch. But after what you told me, I am not so sure anymore.
Obviously there were modifications done and this car is not stock.
I have to move the car to a friends garage before I take anything else apart. Right now I am using a horoscope and looking in the thru the inspection hole in the bell housing.
After I take it all apart, I will take pictures and send them in.
Thank you got your help.
Old 09-07-2020, 10:02 AM   #9
katy
katy's Avatar
Hmmm, interesting.
Old 09-07-2020, 10:13 AM   #10
Jack Shaft
Legacy,love your spell check...hope the horoscope give you inspiration to pull her down...
Old 09-07-2020, 07:51 PM   #11
GRutter
GRutter's Avatar
Ford changed to the single disc clutch after October 1928. If the engine is Dec 28 then the single disc clutch would be correct. Sounds like you have a failed clutch disc. Pull the transmission back and it should be a very straightforward repair. Good opportunity to also replace pilot and throwout bearings.
Old 09-12-2020, 12:22 PM   #12
legacy
legacy's Avatar
The spell check keeps changing my words, it should say " boroscope and inspection"
I will pay more attention next time.
After all, I spent most of my working life doing Inspections using a Boroscope.
Old 10-13-2020, 05:36 PM   #13
legacy
legacy's Avatar
The problem was that the clutch disc came apart.
If I could figure how, I would send you the picture, the disk is in three pieces and all the small pieces were at the bottom of the case.
New disk is installed and works fine.
Old 10-13-2020, 06:35 PM   #14
Jim/GA
Jim/GA's Avatar
Does it look like the clutch that came apart was one of the clutch disks with the ring of small springs between the center hub and the rest of the clutch disc? Kind of like this:
Then those springs would make up the debris you found in the bottom of the flywheel housing?
Jim Cannon
"Have a Model A day!"
Old 10-13-2020, 06:42 PM   #15
McMimmcs
McMimmcs's Avatar
[/B]
Don’t let it bother you, we all knew what you meant and there is not one of us that is perfect!
Old 07-04-2021, 02:40 PM   #16
legacy
legacy's Avatar
Thanks
As it turns out, my car has a single clutch disk not a multi disk as I thought.
The problem or the noise was because the disk came apart and bits and pieces were rolling around at the bottom of the case.
File Type: jpg 9FAE7E85-0D32-458C-B4EB-322B31230C91.jpg (52.0 KB, 334 views)
Old 07-04-2021, 03:07 PM   #17
legacy
legacy's Avatar
Thanks everyone, for all the replies and suggestions.
Old 07-04-2021, 06:55 PM   #18
burner31
burner31's Avatar
Well that's a drag, sorry that your first experience with your A is a blown out clutch, hoping that once you get it back together your next experiences will be happy ones.
Being a good mechanic really helps when owning a Model A and pays off when out enjoying your car.
Welcome to the Barn
Keith
Shawnee OK
'31 SW 160-B
Old 07-04-2021, 08:55 PM   #19
Doug Linden
Doug Linden's Avatar
Yes, unfortunately this problems happens every once in while. Some of the clutch discs don't have cages to hold the springs and they may come loose and cause the disc to fail. Find a replacement disc that has the cages holding the springs.
Doug Linden is offline   Reply With Quote
Old 07-04-2021, 09:07 PM   #20
mercman from oz
mercman from oz's Avatar
Glad that you were able to find out the noise problem you were having.
