Old 08-03-2020, 06:33 PM   #1
Cpuckett
Default Mounting new tires on freshly painted wheels
Just had my wheels painted Tacoma Cream and need to mount new tires on them. Anyone know any tricks/tips on what to do so they won’t be scratched or chipped?
Thanks
Cpuckett is offline   Reply With Quote
Old 08-03-2020, 06:48 PM   #2
chrs1961815
chrs1961815's Avatar
Default Re: Mounting new tires on freshly painted wheels
How we did our wheels recently was get a moving blanket and two blocks of wood to lay the wheel on. That way you won't scratch it and you are able to access the other side.
"The more things change, the more they stay the same."
chrs1961815 is offline   Reply With Quote
Old 08-03-2020, 07:04 PM   #3
Marshall V. Daut
Check your "Private Message" in the upper right corner of this web page.
Marshall
Marshall V. Daut is offline   Reply With Quote
Old 08-03-2020, 07:25 PM   #4
Charlie Stephens
Marshall
Marshall,
Please share your knowledge with the rest of us.
Charlie Stephens
Old 08-03-2020, 07:58 PM   #5
Cpuckett
Smile Re: Mounting new tires on freshly painted wheels
Originally Posted by Charlie Stephens View Post
Marshall,
Charlie Stephens
Marshall
Thanks Marshall!!!!
Old 08-04-2020, 11:44 AM   #6
Purdy Swoft
Purdy Swoft's Avatar
I use GO JO original hand cleaner as a lubricant when installing new twenty one inch tires. I have been able to install new tires by hand when using go Jo as a lubricant. It probably wouldn't be as easy on the later nineteen inch wheels because they don't use the round bead that the earlier twenty one inch wheels mostly use .
Old 08-04-2020, 12:44 PM   #7
1928Mik
1928Mik's Avatar
I have heard of using trash bags to protect the wheel as you are mounting the tire.
1928 Niagara Blue Phaeton
1972 Olds 442 Convertible
1979 MGB
-Life's Too Short To Drive Boring Cars-
1928Mik is offline   Reply With Quote
Old 08-04-2020, 01:14 PM   #8
Tom Endy
Tom Endy's Avatar
See attached article.
Tom Endy
Old 08-04-2020, 06:36 PM   #9
Cpuckett
Tom Endy
Great info, thanks!!!
Old 08-05-2020, 05:14 AM   #10
RonC
RonC's Avatar
Here’s how Ford did it!
https://youtu.be/PflFp8Cdrzc
RonC is offline   Reply With Quote
Old 08-05-2020, 04:44 PM   #11
Jeff/Illinois
Jeff/Illinois's Avatar
I wonder if that guy is still available and what he'd charge
Neat video thanks for posting. He was sure quick. Can you imagine the carpal tunnel these guys had to suffer from for using their hands and wrists like that all day long? John Deere outsourced tire mounting at the factories years ago, because so many guys were having carpal tunnel issues it was tearing them up.
Old 08-05-2020, 05:22 PM   #12
2935ford
2935ford's Avatar
Gee, that was easy!
2935ford is offline   Reply With Quote
Old 08-07-2020, 09:43 AM   #13
Digger
Digger's Avatar
I am due to paint my 19” rims, how about info to take tire off, or should I bring to a recommended tire store who is familiar...
Digger is offline   Reply With Quote
Old 08-07-2020, 12:18 PM   #14
31pickup650
31pickup650's Avatar
I did this and it worked great.
-Noah
1931 Model A Pickup
My Model A : http://www.fordbarn.com/forum/showthread.php?t=173024
31pickup650 is offline   Reply With Quote
Old 08-07-2020, 02:04 PM   #15
Cpuckett
I just had a regular tire place remove them since I’m replacing the tires/tubes
Old 08-07-2020, 10:35 PM   #16
160B
160B's Avatar
The best way to change a tire is to build a platform using 2X4 and plywood. Cut out the center so you can lay the wheel hubcap side down and remove the tire from the back side. Cover the platform with a carpet. I used indoor out door carpet.
Break the bead on the front and the back of the tire. Place a plastic garbage bag over the rim and tuck the bag into the tire. Use a small tire iron and I use a piece of hard plastic to protect the paint on the rim and then work the tire off the rim. Remove the inner tube and repeat the process to remove the tire from the rim.
To install the tire place the plastic bag over the rim and work the tire onto the rim, this can be done by hand but if you need to use the tire iron and the piece of hard plastic to work the tire on the rim. Remove the plastic bag, install the inner tube.
Place the plastic bag over the rim and work the plastic bag between the tire and the rim and work the tire onto the rim, this can be done by hand, or your foot. If you need to you can use the tire iron and the piece of hard plastic to work the tire on the rim.
1931 160B & 1931 68B
If you don't have time to do it right the 1st time, how do you have time to do it the 2nd time?
160B is offline   Reply With Quote
