Old 02-02-2024, 03:53 PM   #21
Pete
Pete's Avatar
Default Re: High Compression Head
Originally Posted by jeepguy1948 View Post
What is y’all’s opinion on the best head gasket for an aluminum head?
Fel Pro 7013 for a street engine.
Solid copper with O-ring for race engine.
Old 02-02-2024, 03:56 PM   #22
Pete
Pete's Avatar
Originally Posted by johnneilson View Post
No
The exit speed of mile 3 wins
Ha!
J
Very true, but he will also still have the biggest dyno numbers...lol
Old 02-05-2024, 11:16 PM   #23
jeepguy1948
Thank you Pete
jeepguy1948 is offline   Reply With Quote
Old 02-07-2024, 12:55 PM   #24
ModelA29
ModelA29's Avatar
No
Ha!
J
Only if you swap the engines into the same car for each test. Cheating the aero is a big part of it.
A car cruising at 50 mph may require only 10 horsepower to overcome aerodynamic drag, but that same car at 100 mph requires 80 hp. With a doubling of speed the drag quadruples. A car has a lower drag coefficient that only takes 8 horsepower to maintain 50 will only need 64 ponies to run 100.
ModelA29 is offline   Reply With Quote
Old 02-07-2024, 02:16 PM   #25
johnneilson
I am still working on breaking 190 mph
We are pushing around 300 hp
Both the motor and I are sweating….
J
As Carroll Smith wrote; All Failures are Human in Origin.
johnneilson is offline   Reply With Quote
Old 02-07-2024, 05:48 PM   #26
updraught
updraught's Avatar
If you use a smaller pulley on the two blade fan it'll pull all the air thru the radiator and create a vacuum in front of the car?
updraught is offline   Reply With Quote
Old 02-07-2024, 06:43 PM   #27
Pete
Pete's Avatar
With a big enough fan, the car becomes an airplane and they do not let airplanes run in that class.
Old 02-07-2024, 07:47 PM   #28
Keith True
Keith True's Avatar
The only performance numbers I ever thought to remember were told to me by Cummins engineering in the mid 80's.He said it takes 239 HP to maintain 65 MPH in a cabover truck with a box grossing 80,000,level road,no wind.He said there were variables,different gearing,radial or bias tires,smooth or outside post trailers,air quality,outside temp,etc.But,he also said that was a surprisingly accurate number even with all the variables.Came into my mind probably hundreds of times as I rowed with two sticks behind a 220 Cummins,hoping to hit 60.
Old 02-08-2024, 07:21 AM   #29
updraught
updraught's Avatar
One for sale:
https://www.ebay.com/itm/17602174552...gAAOSwBhNlTRay
Old 02-08-2024, 08:16 AM   #30
johnneilson
Ohh, I have a fortune!
I have a pile of those laying behind the dyno shed
I’ll post the eBay link soon
Come and get them, John
Old 02-08-2024, 08:35 AM   #31
old31
At that price you would think the guy would ship it for free, geeeeeez.
old31 is offline   Reply With Quote
