Old 09-20-2021, 08:36 AM   #1
Ford coupe
Angry Power steering control valve 79 Granada
My brother rebuilt the power steering control valve and now the car steers to easily to the right and way to hard to the left..Was a difficult job putting kit in unit but got it done ..so any help appreciated to help him out of a bind.. Thanks in advance..
Ford coupe is offline   Reply With Quote
Old 09-20-2021, 10:13 AM   #2
Merc Cruzer
Merc Cruzer's Avatar
Default Re: Power steering control valve 79 Granada
The control valve has seals at each end. More likely that not, one seal has blown out and the other one is still working. Picture of the control valve, out of my 53', at the bottom, with arrow, but the same basic system was used into the 70's .
Merc Cruzer is offline   Reply With Quote
Old 09-20-2021, 03:20 PM   #3
Ford coupe
Did put all new seals from the kit in it...Could you maybe posy a schematic of it to help
Old 09-20-2021, 04:01 PM   #4
Merc Cruzer
Here is a coupe of diagrams of the 53' system.
The problem is that if you bought a NOS set of seals, they are 42 years old.
Below is an article I did previously, that might provide some insight:
https://www.fordbarn.com/forum/showt...RhwPUGJ1GqEwv0
Old 09-20-2021, 08:14 PM   #5
Ford coupe
Would i have an oil leak if either seal leaking?Rebuild kit with seals came from rock auto ..Now maybe that tells you something..No there is no sign of oil leal..Thanks so much for the info..Harry
Old 09-21-2021, 08:48 AM   #6
Merc Cruzer
You might want to give it one more try to clear any air out of the system. While running, turn the wheel all the way to the right then all the way to the left. Do that 3 times, to see if it gets any better.
A few more pages pertaining to assembly.
Old 09-22-2021, 08:30 AM   #7
Ford coupe
Thanks but looks like going to buy a new one as no leaks no air and everythingblooks right but steering to right no effort as it almost steers itself,,scary..To left almost like standard steeruing..Thanks for trying to help///Harry..
Old 09-22-2021, 04:49 PM   #8
5851a
Been 45 years since I did one but I seem to remember a critical centering adjustment on the spool valve. There are some You tube videos of an early Mustang PS rebuild. Should be the same process.
5851a is offline   Reply With Quote
Old 09-22-2021, 05:09 PM   #9
Merc Cruzer
It is done with this nut, which is under the cap in the second picture. If the nut is really tight, back it off and see if that helps.
Old 09-22-2021, 05:10 PM   #10
KULTULZ
KULTULZ's Avatar
Thumbs up Re: Power steering control valve 79 Granada
MERC CRUISER was kind enough to post the pages from the WSM on adjusting the valve.
- WHY IS IT ... -
... that everything you buy in the grocery store is either wrapped in or contained in plastic but the government doesn't want you to carry it out in a plastic bag?
WONDERING IN W(BY GOD)V ...
DIAGNOSED CDO - (OCD In Correct Alphabetical Order)
KULTULZ is offline   Reply With Quote
Old 09-22-2021, 05:58 PM   #11
5851a
That's the one, Thank you Merc Cruiser.
Old 09-22-2021, 07:24 PM   #12
Merc Cruzer
The manual says: "Tighten the nut until solid, then back off the nut a 1/4 turn"
