Old 09-10-2021, 07:24 AM   #1
1930artdeco
1930artdeco's Avatar
Default New gas tank
I just got a new tank and compared it to my original one. Besides being about 1.5” shorter it looks great and can’t wait to install it. My question is this, the original has little rubber blocks on the top so what else do I have to add to it? I know the straps are supposed to have a rubber covering on them. I thought I heard about there being some rubber tape on the edge where it contacts the body, if so where do it get it?
Thanks,
Mike
1930 TownSedan (Briggs)
1957 Country Sedan
Old 09-10-2021, 08:59 PM   #2
paul2748
paul2748's Avatar
Default Re: New gas tank
Rubber tape on the edge of what? the tank - do you mean the seam? The seam doesn't touch the body. As far as i know, you just have the rubber blocks on the top plus something on the straps where the tank is. Later (57) used a cloth type material between the tank and the straps - not sure about what was used earlier.
The cloth type material can be purchased from a TBird parts supplier, assume any old Ford parts supplier has it.
Thanks,
Mike
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 09-10-2021, 10:52 PM   #3
dmsfrr
dmsfrr's Avatar
Since the tank mounts with rubber blocks and some cushion strips...
Use an Ohm meter or a test light and make sure the fuel sensor in the tank has a good Ground to the body of the car, or the fuel gauge may not indicate correctly.
You may need to add a Ground wire for it.
dmsfrr is offline   Reply With Quote
Old 09-11-2021, 08:11 AM   #4
Ford blue blood
Ford blue blood's Avatar
All of my 57s had a ground wire on the tank. It was tied to one of the sender screws. My 58 Edsel Pacer had no isolation between the tank and the chassis/body and still has the ground wire on the sender. Is there really a "standard" for these cars?
Bill, certified Ford nut.
2016 F-150
2016 Focus
08 Shelby GT500
57 Ford Ranchero
36 Chevy, 351C/FMX, 8", Mustang II
Ford blue blood is offline   Reply With Quote
Old 09-11-2021, 11:59 AM   #5
1930artdeco
I just had heard that there was some sort of insulator between the tank and the body-outside of the rubber blocks. I assume it is for vibration insulation. But I can run a ground wire from one of the outlet holes-it came with an outlet and return line. But good point on the ohm meter to see what I get from the sending unit.
Mike
1957 Country Sedan
Old 09-11-2021, 08:53 PM   #6
Daves55Sedan
Daves55Sedan's Avatar
There are some rubber pads between the tank and the trunk floor that can be re-used and transferred to the new tank. This was done at the factory to prevent noise, friction and eventual wearing between the tank and ribbing in the trunk floor. (There is a small amount of deflection between frame and body during body-roll events, such as turning corners or going over bumps and potholes).
For the gas tank straps, you can just cut two strips (one for each strap) of roofing felt and glue the felt to the top surface of the strap, or just lay it in between the strap and tank and it should stay there sandwiched between the strap and tank. I have done it that way on two cars.
Daves55Sedan is offline   Reply With Quote
Old 09-12-2021, 01:14 PM   #7
56sedandelivery
56sedandelivery's Avatar
Are those pads available? When I removed my tank they were is very sad shape.
56sedandelivery is offline   Reply With Quote
Old 09-12-2021, 02:13 PM   #8
Daves55Sedan
Originally Posted by 56sedandelivery View Post
Are those pads available? When I removed my tank they were in very sad shape.
Not to my knowledge, but you don't need 1/8" thick, 1-1/2" wide rubber pads anyway. Just go to the hardware store and get a roll of self-stick foam rubber strips as wide as you can find them and place strips at the high point of the ribbing of the tank. Try to get the dense foam rubber, not the cheap squishy stuff.
If all they have is the squishy stuff, get the thicker strips (about 1/4" to 3/8" thick) and it will smash down when you tighten the gas tank straps up.
Old 09-12-2021, 04:32 PM   #9
dmsfrr
dmsfrr's Avatar
Are those pads available? ...
Maybe. Look around at the websites of or call the various restoration parts suppliers and ask.
The gas tank pads are available for '55/'57 T-Birds and might(?) be a similar size, I don't know.
When I put in a new tank I used some thick rubber pond liner leftover from a landscaping project. Probably shouldn't have covered the whole top of the tank so it could stay drier and not rust later.
But it's really dry here...
Old 09-12-2021, 07:54 PM   #10
paul2748
paul2748's Avatar
The pads are available from the Tbird pats vendors, most likely the non TBird vendors. I just helped a friend put a new tank in his 57 Bird and he had new rubber pads.
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 09-14-2021, 06:41 PM   #11
1930artdeco
Got some new pads and strap 'covers' from the local T-bird store. Is it worth stripping the oil/grease/cosmolene off of the tank and clear coating it to protect it from rust?
Mike
1957 Country Sedan
Old 09-14-2021, 08:21 PM   #12
paul2748
paul2748's Avatar
If you want it to look nice, yes, it's worth it.
Mike
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 09-15-2021, 06:58 AM   #13
Patrick brophy
Are the tanks painted when new?
Patrick brophy is offline   Reply With Quote
Old 09-15-2021, 07:23 PM   #14
paul2748
paul2748's Avatar
I think they are zinc plated (or some other type of coating)
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 09-16-2021, 06:39 PM   #15
1930artdeco
According to Auto City Classics they don't need to be painted as they are coated from the factory. I called and the guy I talked to said that I could paint it with a zinc spray paint from Eastwood. I looked it up and it is about $13 a can and they generally takes two cans. I was just curious as I just didn't want it to start rusting, that is all. But since it is already coated I will just install it.
Mike
1957 Country Sedan
