12-28-2020, 08:59 AM | #1 |
Petronix better ?
Do their 6v coils really deliver a noticeable umph? Dependable?
12-28-2020, 09:24 AM | #2 |
Re: Petronix better ?
Unless they have made an improvement, their 6v systems were subject to failure with generator voltage spikes. The old fashioned dist. machines will set up a flathead dist. for more RPM than the engine will make.
12-28-2020, 09:32 AM | #3 |
so who is hottest 6v ?
12-28-2020, 10:48 AM | #4 |
Use points, condenser and skip’s coil - problems solved. Very dependable.
12-28-2020, 11:04 AM | #5 |
Coil will only produce as much voltage as required to jump spark plug gap. Doesn't matter what it says on the coil. Anything over 10K volts is probably OK for a flathead.
12-28-2020, 11:33 AM | #6 |
12-28-2020, 12:23 PM | #7 |
Also, there is something very self-satisfying about understanding how all of the mechanical aspects of your vehicle function and being able to keep them maintained in tip-top operating condition.
12-28-2020, 01:31 PM | #8 | |
Will it deliver a noticeable umph? The answer, NO. Dependable? YES.
12-29-2020, 07:16 PM | #9 |
12-30-2020, 03:11 PM | #10 |
A coil with a 1.5-ohm primary winding will only step the voltage so far. The reliability is the thing to look for. One built with modern materials should work just fine. Some folks like the Pertronics and some like the Bosch silver coils. NAPA Echlinc coils used to be pretty good too. In this day and age, I couldn't say how reliable any of them are.
Skip does a decent job of upgrading the old ones to a good state of reliability. http://www.fordcollector.com/coils.htm |
