Old 01-28-2020, 07:00 PM   #21
rotorwrench
rotorwrench's Avatar
Default Re: Brake Light Switch Backwards
Brake light switches of the pressure activated type are becoming less common for design in the modern era. A lot of them are Hecho in Mexico now days. I've had several new ones go bad and even start leaking. The old ones lasted a life time but they guy that owned the car before died so the life time is up.
Old 01-28-2020, 07:53 PM   #22
Chris Haynes
Chris Haynes's Avatar
Originally Posted by Bob C View Post
Is this how your switch is mounted??
I have never seen a switch mounted there. All I have seen were on the X member.
1921 Runabout
1930 Tudor
Early 1930 AA
Speed costs money. How fast do you want to go?
Chris Haynes is offline   Reply With Quote
Old 01-28-2020, 11:15 PM   #23
Jeff M
Originally Posted by redmodelt View Post
Re "most hydraulic switches fail quite often" Maybe you would like to explain that one a bit more or were is that information coming from?
Up at the start of this you said you took it apart, was not sure why you would take a new switch apart, but maybe that has something to do with it.
I took it apart because the aftermarket '28-'29 switches are known for not working out of the package. When I took it apart the contacts didn't touch with the plunger pulled back, so I fixed that issue before installing it.
Originally Posted by Patrick L. View Post
With hydraulic brakes I too would have probably used the master cylinder switch. They were used reliably for decades. But, he decided to use a mechanical switch.
I'm using a later dual circuit master cylinder, not a factory style early Ford with the rear mounted switch.
Exactly!
That is where the '28-'29 switches are mounted, I'm using the earlier switch on my '30.
I've been tied up all week but I plan to get some shop time in tomorrow and figure what's going on.
Jeff M is offline   Reply With Quote
Old 01-29-2020, 09:18 AM   #24
Patrick L.
Patrick L.'s Avatar
Well, if you're using hydraulic brakes then the dual cylinder is a good idea. And I do agree with the opinion of a lot of new parts nowadays.
Old 01-29-2020, 09:43 AM   #25
ryanheacox
ryanheacox's Avatar
I can't help but think the problem has to be in the switch still. If you're sure that there is no grounding issue I don't know what else the problem can be. A quick check would be to put an ohmeter across the switch with the battery disconnected and check the continuity.
ryanheacox is offline   Reply With Quote
