Old 10-16-2017, 11:21 AM   #1
dean from bozeman
dean from bozeman's Avatar
Default Not Model A: '80 Thunderbird problem
Years ago I had my mom's '80 T-Bird "restored". It was the only car that she ever drove. My dad did not let her get a driver's license until she was 55 years old.
I drove it a bit but since I had no on-site place for it, I put it in storage in town. When I did this I thought that I had run the gas out. You can see where I am going with this.
Recently, I finally finished my new shop and now would have a place for it. However, when I went to get it, I realized that I had left 3/4 of a tank of gas in it. Though it smelled like varnish I still drove it up onto the trailer. Now that it is home I need to get that gas out of it before I drive it any more.
The filler tube has a screen on it so I cannot siphon it out. A friend said to put ice under it, remove all bolts and when the ice is gone and it is lowered slide it out from under the car. However, this car has a metal guard that protects the front 1/3 of the tank so it cannot be easily lowered down.
Another friend says disconnect the coil and gas line. When you go to start it with the key, the gas tank pump will eventually remove most of the gas. It seems like this would take forever and possibly burn out the starter.
On the front of the tank there is a 2 to 3" cover with the gas line and a sensor wire for how full the tank is. I don't know how to remove this and then reseal it. However, since the tank is so full would removing this just spill gas all over?
I thought of even contacting the local Ford dealership but I think that they would balk at removing 3/4 of a tank of varnish gas even though I do have a friend who would take this varnished gas.
I'm asking for information on how to solve this problem or a T-Bird site/person who could act as a source of information. Help!
Thanks for allowing me to post a non-Model A problem and for any help that you can offer.
Dean
P.S. True confession: 95% of my work on automobiles is working on Model A's. Other than maintenance, I do not work on modern vehicles. I consider this '80 T-Bird to be a modern vehicle.
dean from bozeman is offline   Reply With Quote
Old 10-16-2017, 11:42 AM   #2
Dodge
Default Re: Not Model A: '80 Thunderbird problem
Buy a cheap electric fuel pump and put it on the line going to the fuel pump and pump all the gas out into a container. Get a $15 one from ebay.
Dodge is offline   Reply With Quote
Old 10-16-2017, 11:44 AM   #3
SeaSlugs
SeaSlugs's Avatar
So I assume it has a mechanical pump? Do you have a lift or at least tall ramps to elevate the rear?
Can you get to the fuel lines going to the pump and start a siphon (dont use your mouth...) and let it drain into a bucket(s)
Then refill with fresh gas and run the car for awhile to burn out any leftover gas then change the fuel filter(s)
1929 Model AA - Need long splash aprons!
SeaSlugs is offline   Reply With Quote
Old 10-16-2017, 11:48 AM   #4
jhowes
If this car has an electric fuel pump then the starter will not be burned out emptying the tank (at least in a Model A) If it has a mechanical pump, wouldn't just disconnecting the fuel line at the pump allow it to drain into a catch basin of some sort? Maybe jack the rear up a bit to encourage gravity flow.
Jack
jhowes is offline   Reply With Quote
Old 10-16-2017, 12:04 PM   #5
Y-Blockhead
Y-Blockhead's Avatar
Dean, Why not ask on the late V-8 Forum here on the Ford Barn? https://www.fordbarn.com/forum/forumdisplay.php?f=5
Originally Posted by dean from bozeman View Post
... the gas tank pump will eventually remove most of the gas.
If the pump is in the tank it is electric. I would just route your fuel line to a gas can and turn on the switch to pump it out. If the gas is really bad it may plug your in-line filter tho.
Old 10-16-2017, 12:32 PM   #6
jw hash
jw hash's Avatar
Dean
good to see you in Hershey, two things you said you drove it into the trailer, that is a plus. the gas in the tank is not all that bad or the motor would not have started. look under the for a drain plug. if you get the tank drain down and put clean gas in it. you might get lucky. John
jw hash is offline   Reply With Quote
Old 10-16-2017, 04:42 PM   #7
dean from bozeman
John, not lucky enough. No drain plug. Go figure.
Y-Blockhead, good idea. I did put it on Late V8 forum.
jhowes, will the pump run with the key in the on position? Would I need to disconnect the coil?
Dodge, are such pumps available at NAPA?
Seaslugs, I like your idea. As a kid we would steal gas by siphoning it. I have some experience.
Thanks to all.
This weekend, I will try one or more of your ideas.
Dean
Old 10-16-2017, 05:13 PM   #8
1crosscut
1crosscut's Avatar
NAPA will have the pumps.
Dave / Lincoln Nebraska
1crosscut is offline   Reply With Quote
Old 10-16-2017, 07:32 PM   #9
mike657894
mike657894's Avatar
get your self one of those squeeze ball siphon lines and take off the fuel hose going into the mech pump and conect your siphon hose set it into a can on the ground and wala dont forget change out the can or it will make a 10 gallon puddle.
mike657894 is offline   Reply With Quote
Old 10-16-2017, 07:35 PM   #10
mike657894
mike657894's Avatar
after you get out most of it you will be left with 1/2 to 2 gallons. pour in some fresh gas to mix with that and get that out or drop the empty tank and do more work. i would flush it out with 20 dollars worth of fresh stuff.
Old 10-16-2017, 08:17 PM   #11
ModelAMike1930
ModelAMike1930's Avatar
Harbor Freight has a cheap pump that I have used to pump gas out of my model a when I put a new gas gauge in it.
ModelAMike1930 is offline   Reply With Quote
Old 10-16-2017, 09:53 PM   #12
Dodge
Yes napa will have the electric pump but it won't be $15
Old 10-16-2017, 10:24 PM   #13
texas webb
If you drop the tank,clean it out with 1-2 gallons of E-85 gas.Swish it all around then dump it.
texas webb is offline   Reply With Quote
Old 10-17-2017, 01:34 AM   #14
Tom Wesenberg
Tom Wesenberg's Avatar
Buy this pump from California, connect it to the line going to your engine fuel pump, then pump the tank dry. Put in new gas with MMO and go for a drive.
http://www.ebay.com/itm/New-Low-Pres...FZQkjv&vxp=mtr
Old 10-17-2017, 04:21 AM   #15
Dodge
Amen
Old 10-17-2017, 06:27 AM   #16
desotoguy
If you are going to drive it you might a well do the job right. The tank needs to be removed, floor jack to lower tank, and flushed out. You also need to replace all rubber fuel lines with new ones for ethanol gas. Interesting information on ethanol gas can be found here: http://www.lcbamarketing.com/phase_s...hanol_blen.htm
Big job
desotoguy is offline   Reply With Quote
Old 10-17-2017, 12:34 PM   #17
SeaSlugs
SeaSlugs's Avatar
Big job
I would hope by 1980 Ford also had ethanol safe rubber stuff - should say in the manual. My 1980 chevette manual says its Ok to use E10...Still on the original rubber fuel lines today along with the mechanical fuel pump and fuel tank.
Old 10-17-2017, 12:50 PM   #18
Licensed to kill
Licensed to kill's Avatar
How long was it stored?.
Licensed to kill is offline   Reply With Quote
Old 10-17-2017, 01:02 PM   #19
Jeff/Illinois
Jeff/Illinois's Avatar
Interesting let us know how you wind up.
I'd think a plastic plunger type siphon pump would get most of it out or else do like Tom said, that would flush the fuel line to the fuel pump anyway, providing it has a mechanical F.P at the engine or does it have an electric pump in the gas tank? I don't recall how a 1980 Ford was set up.
Jeff/Illinois is offline   Reply With Quote
