Old 10-13-2013, 03:20 PM   #1
ford33
Default 1934 Ash tray radio
Hi Can someone tell me the length of the 34 ash tray radio controle cables? I have 2 pair and one is longer than the other. I don't know which set is for my 34 and which is for my 35 radio.
Thanks
ford33 is offline   Reply With Quote
Old 10-13-2013, 06:40 PM   #2
thirt4
thirt4's Avatar
Default Re: 1934 Ash tray radio
On mine, one connects to the tuner connector and the other to the On/Off connector. Pretty simple. Should be able to measure from there. If not, I could go out and measure mine... but wait... I just remembered I took mine out to have it re-faced and have already disconnected the cables. If those are all that you need measured, I can still do that part.
thirt4 is offline   Reply With Quote
Old 10-13-2013, 07:16 PM   #3
Randy
Randy's Avatar
I can't tell you the length, but one is longer than the other as it has a longer path to the radio.
Randy is offline   Reply With Quote
Old 10-13-2013, 07:34 PM   #4
ford33
Yes, all I need is the length of the cables
