Old 02-25-2012, 09:55 AM   #1
30six
30six's Avatar
Default Headlight wiring
I need to replace headlight wiring on my 36.
Before I pull out old wiring and put in new are there any things I should know, do or follow?
Does the wire harness to headlights feed easily through headlight stand?
Thanks,
Electrically challenged
30six is offline   Reply With Quote
Old 02-25-2012, 10:44 AM   #2
Lawson Cox
Lawson Cox's Avatar
Default Re: Headlight wiring
You need a wiring diagram and patience. Not a hard job. Just follow the diagram and color codes.
Old 02-25-2012, 11:12 AM   #3
Brendan
Brendan's Avatar
it was easy for me to rewire my pickup, like Lawson said you need a wiring diagram and be able to read it. the hardest thing was to get all the wires into the conduit on the drivers side. i was replacing my motor and wiring at the same time. i had all the wiring installed on the motor before i put it in.
If it would have been a snake it would have bit ya!
i can't spell my way out of a paper bag!
Brendan is offline   Reply With Quote
Old 02-25-2012, 06:40 PM   #4
Mike in AZ
Mike in AZ's Avatar
wiring should be easy....i hope.....and here's a link to MacVP's website with a wiring schematic...good luck...Mike
http://www.vanpeltsales.com/FH_web/F...wiring1936.jpg
Mike in AZ is offline   Reply With Quote
Old 02-25-2012, 07:24 PM   #5
30six
30six's Avatar
Mike: Thanks!
Thought I had the short in headlight socket fixed until I put new socket in.
Turned headlight switch on, checked lights only to smell wires frying....time to replace
harness.
Old 02-25-2012, 08:46 PM   #6
JJOHN
Had a short under the dash from an old dried out wire insulation, dam near had a major fire. Called Tyree Harris for new wiring harness from front to rear and took my time replaceing the wires with instructions provided, no problems and ome peace of mind now.
JJOHN is offline   Reply With Quote
Old 02-25-2012, 10:05 PM   #7
Lawson Cox
Lawson Cox's Avatar
Tyree makes a good product. You did well using his harnesses.
Old 02-25-2012, 11:11 PM   #8
Hank the 36
Does Tyree Harris have a web-site or number ? I might be next to tackle this issue.
H36
Hank the 36 is offline   Reply With Quote
Old 02-26-2012, 08:45 AM   #9
Bruce/CT
TYREE HARRIS [email protected]
Great product; great guy. I'm not sure if e-mail is the best way to gert him. I've only spoken to him by phone and at Hershey. He lives in Bumpass, Virginia. When I get down to the garage I'll look for his phone number and post it here if someone doesn't beat me to it. You won't be dissappointed.
Bruce/CT
Failure is simply the opportunity to begin again, this time more intelligently.......Henry Ford
Bruce/CT is offline   Reply With Quote
Old 02-26-2012, 12:40 PM   #10
Terry,OH
Terry,OH's Avatar
You can cut one or two of the bullet wiring connectors off and feed the wires through the hollow bold and reinstall new ones. I do not know why the harnesses are made with equal length wires on the harness end. You can not feed three of the connectors through the bolt at the same time. If they were slightly different in length you can get them in the bolt.
The light bulb sockets do not come with the harness (reuse old )so make sure the harness comes with the small mushroom shaped connectors (do not need to crimp)and enough to do all the bulbs. when soldering electrical wires use rosin core solder, Radio Shack has the good thin solder.
Tyree: 804 556-5200
2693 Crewsville Rd.
Bumpass, VA 23024
