Old 11-26-2020, 07:01 AM   #1
bobsmanstuff
bobsmanstuff's Avatar
Default gas
Happy Thanksgiving Guys. I've got a question about something I wondered for awhile. I have a 53 customline with aluminum heads. Is it better to run non- oxy gas or regular? Thanks Bob
bobsmanstuff is offline   Reply With Quote
Old 11-26-2020, 08:05 AM   #2
corvette8n
corvette8n's Avatar
Default Re: gas
I run non ethanol gas in mine, only problem in my area it’s only available in high octane(premium). Hope that answers your question.
Old 11-26-2020, 09:54 AM   #3
joe 1950
joe 1950's Avatar
Default Re: gas
Do yourself a favor and don’t use any fuel with ethanol it isn’t good for anything in the fuel system hoses ,carb,pump where i live in wisconsin we have a Fleet Farm store that has a mid grade 89 octane with no ethanol it’s @ 70 cents a gallon more but but worth it
joe 1950 is offline   Reply With Quote
Old 11-26-2020, 10:18 AM   #4
19Fordy
19Fordy's Avatar
Default Re: gas
Is there an additive you could add with each tankful that would negate the bad
effects of ethanol gas?
19Fordy is online now   Reply With Quote
Old 11-26-2020, 10:43 AM   #5
Jacques1960
Jacques1960's Avatar
Default Re: gas
Hard to neutralize corn syrup.
No job’s done ‘til it’s all done
Jacques1960 is offline   Reply With Quote
Old 11-26-2020, 11:07 AM   #6
Charlie ny
Default Re: gas
Hmmm, 87 oct corn gas seems to work OK for me.
Charlie ny
Old 11-26-2020, 11:16 AM   #7
tubman
tubman's Avatar
Default Re: gas
I've never had a problem with "corn gas" either, but that's probably because I only use it as a last resort. I notice the O/P is from Minnesota. No alcohol premium is very common in this state, because of the marine connection (the "Land of 10,000 Lakes" you know) and the efforts of the Minnesota Street Rod Association. In my opinion, it's worth the extra cost.
I think Charlie has a built in advantage over the rest of us.
Old 11-26-2020, 11:39 AM   #8
estout81
Default Re: gas
I use "corn gas" in my engines. Flatheads, overheads, old farm tractors and lawn mowers with no ill effects. Shut most of them off in November and start them in March. No additives used! "Corn gas" has been around sense, at least, the early '30s.
estout81 is offline   Reply With Quote
Old 11-26-2020, 01:04 PM   #9
50fordcoupeman
50fordcoupeman's Avatar
Default Re: gas
I use non-ethanol in everything I own that has a carburetor.
50fordcoupeman is offline   Reply With Quote
Old 11-26-2020, 04:08 PM   #10
hotrodart
hotrodart's Avatar
Default Re: gas
Maybe the ethanol/gasoline formulations are different across the country.....E10 fuel in my area corrodes aluminum and pot metal parts (carburetors) and creates havoc with "old" rubber formulations. Also, I had to replace a gas tank from rust caused by water separation in the tank. My Honda generator absolutely dislikes E10 fuel over one week old.......sputters and stops......changed to non-E gas and have no issues at all. My tractor and other yard equipment seem to do OK with E10.
hotrodart is offline   Reply With Quote
Old 11-26-2020, 05:27 PM   #11
flatford8
flatford8's Avatar
Default Re: gas
I’ve only had trouble with 2-stroke equipment. Chainsaw, weedwacker and a small rototiller all got new carbs because the aluminum carbs got corroded. Happy that a place about ten miles from me got real gas this fall........Mark
File Type: jpg 9C61595F-33DC-4032-B332-23880FCE1DEF.jpg (34.5 KB, 1 views)
I'm thinkin' about crankin'
My ragged ol' truck up
and haulin' myself into town.
Billy Joe Shaver
Old 11-26-2020, 08:26 PM   #12
aussie merc
aussie merc's Avatar
Default Re: gas
this old story again ethanol is good old fashion moonshine nothing wrong with it if your engine is built to run on it thats the hard part its alcohol and must be treated as such all parts must be alcohol proof and no problems NOS parts aren't, alcohol was used as a solvent in their production so using ethanol fuel your basically slowly dissolving the part so take the time spend the dollars and buy alcohol resistant parts or find ethanol free fuel and tune accordingly
aussie merc is offline   Reply With Quote
