09-19-2017, 10:27 AM | #21 | |
Re: Checking bottom end bearing clearances
I would think oil viscosity would be a factor. Dial indicating an A main with 30W or 40 oil in it may not give an accurate reading. Modern engines with 0W or 5W something oil may "squish" the oil out to get a true reading. |
09-19-2017, 10:38 AM | #22 |
When you removed the 4 shims from the rear bearing, you removed only .002" of clearance, (.002" straight down)
09-19-2017, 10:40 PM | #23 |
09-19-2017, 10:58 PM | #24 | |||
09-19-2017, 11:23 PM | #25 | |
Herm. |
09-19-2017, 11:38 PM | #26 | |
Herm. |
