Old 10-04-2021, 09:20 AM   #1
flybob08
Default Brake service rod
My front brake service rod is a straight rod that does not have the nub. Hence, the brake rod return spring serves only as a guide for the rod and does not act as a spring. Is this correct? Acceptable?
flybob08 is offline   Reply With Quote
Old 10-04-2021, 09:48 AM   #2
katy
katy's Avatar
Default Re: Brake service rod
is this correct?
no
acceptable?
no
Old 10-04-2021, 09:49 AM   #3
flybob08
Ug!
Old 10-04-2021, 10:15 AM   #4
Patrick L.
Patrick L.'s Avatar
Is it just the one, or, all of them ?
Old 10-04-2021, 10:25 AM   #5
flybob08
Both front brakes
Old 10-04-2021, 11:28 AM   #6
Patrick L.
Patrick L.'s Avatar
Looks like you need a couple rods.
What happened ? Does it look like someone ground them off or something ?
Old 10-04-2021, 11:32 AM   #7
Russell Reay
The center of the nub is 17 1/2" from the center of the fixed end of the rod. I would think you could drill the threads out of a 5/16 nut, cut it half, weld the halves to the rod, and grind it to shape. Of greater concern is why there are no nubs in the first place?
Russell Reay is offline   Reply With Quote
Old 10-04-2021, 11:35 AM   #8
flybob08
It was cheap enough and easier to order a new rod. Not sure why it was missing. Working through the braking system slowly
Old 10-04-2021, 01:18 PM   #9
chrs1961815
chrs1961815's Avatar
Somebody probably took a piece of threaded rod and made one for whatever reason.
"The more things change, the more they stay the same."
chrs1961815 is offline   Reply With Quote
Old 10-05-2021, 08:43 AM   #10
supergnat
supergnat's Avatar
You can buy originals from Berts. That nub is important.
supergnat is offline   Reply With Quote
