Old 11-23-2013, 07:52 PM   #1
28ACoupe
28ACoupe's Avatar
Default AR Wheels
I found a website, or at least some info with pictures on a website that detailed the differences between wheels on the Model A Ford.
Does anyone know of a website like this or possibly have a picture of an AR wheel so I can be reminded of what to look for? Wheels are next on my list of crap to buy.
Thanks
1928 Model A Business Coupe
Rebuild picture gallery here
The light at the end of the tunnel has been turned off due to budget cuts.
28ACoupe is offline   Reply With Quote
Old 11-23-2013, 09:26 PM   #2
'29wagon
Default Re: AR Wheels
I sold some nice AR wheels on here a couple of years ago. The bolt pattern is 5 on 4and7eights, i'd a been real proud if they fit my wagon. The center hole and the disk are entierly different.
'29wagon is offline   Reply With Quote
Old 11-23-2013, 10:18 PM   #3
Mike V. Florida
Mike V. Florida's Avatar
AR wheel? OH an e28 wheel.
Just kidding there is a move on to change the use of AR to the more correct Early 28 (e28). This is due to the fact that any part from any year that was updated and no longer used on the assembly line was given a suffix of AR.
Old 11-24-2013, 09:19 AM   #4
kenparker
kenparker's Avatar
Here arre some pix of an AR -oops early28- wheel compared to an A wheel.
kenparker is offline   Reply With Quote
Old 11-24-2013, 12:03 PM   #5
Rowdy
The bolt pattern is the same, it is the hub flange depth that is different. An early 28 wheel hub flange will not contact the drum when put on a later drum and a later wheel will have about a 1/4" gap behind the lug studs if put on an early 28 drum and will not properly tighten. Both are not good conditions to have. Rod
Do the RIGHT thing - Support the H.A.M.B. Alliance!!!!
Rowdy is offline   Reply With Quote
