Old 01-16-2022, 10:31 AM   #1
oldredford
Default Matching numbers
I have a 1930 coupe that I bought last spring at a nearby swap meet in SC. Such a well preserved car only patch panel is in the rear tire well area. After checking closely all 3 VIN numbers match. The title, engine block and upper rail frame numbers all match. Is it safe to say I have the original engine?
oldredford is offline   Reply With Quote
Old 01-16-2022, 10:38 AM   #2
WTSHNN
WTSHNN's Avatar
Default Re: Matching numbers
What does the surface of the engine number pad look like?
No one wants advice - only corroboration.
-John Steinbeck
WTSHNN is offline   Reply With Quote
Old 01-16-2022, 11:23 AM   #3
oldredford
I took a wire brush and cleaned the numbers. I can't see any stamp over and they look original to me.
Old 01-16-2022, 11:53 AM   #4
Gary WA
Gary WA's Avatar
I'd have to say yes! I have a 1930 Delux Delivery with matching numbers. It came from the Henry Ford Museum. With a Certification from Benson Research center. It was used for the Audio/visual department around campus. Have you done a background check on ownership yet?
www.whidbeymodelaclub.com
Old 01-16-2022, 01:45 PM   #5
katy
katy's Avatar
How did you verify the "upper rail frame number"?
Old 01-16-2022, 07:41 PM   #6
oldredford
I asked Henry Ford.
Old 01-17-2022, 08:26 AM   #7
aermotor
I asked Henry Ford.
Did Henery give you a letter for future reference?
aermotor is offline   Reply With Quote
Old 01-17-2022, 11:33 AM   #8
Gene F
Gene F's Avatar
Gary, how would one do this? "Have you done a background check on ownership yet?"
Old 01-17-2022, 11:51 AM   #9
rfitzpatrick
I asked Henry Ford.
I might know your Brother.
Tks just the same
rfitzpatrick is offline   Reply With Quote
Old 01-17-2022, 11:57 AM   #10
goodcar
You should be able to tell if the original engine number has been ground off and restamped. If the pad has a slightly rough texture matching the rest of the engine it is probably original. If very smooth, then it has probably been restamped. Nice to know but not a big deal. More important is the condition of the engine.
goodcar is offline   Reply With Quote
Old 01-17-2022, 12:59 PM   #11
Gary WA
Gary WA's Avatar
Yes It was in pretty rough shape mechanically, Didn't run etc. Sent email to Benson Research center.
