03-07-2021, 10:46 AM | #1 |
Parking brake
Hi,
The parking brake on my ‘39 standard will not catch when pulled out. Would someone post a photo of the top side of the handle. Mine has a small plate with a flat spring attached with a hose clamp and it works, remove the hose clamp and the spring and it won’t catch. I have photos but the site won’t upload them.
Cheers, Jim&Sandy McGregor, IA |
03-07-2021, 01:27 PM | #2 |
Re: Parking brake
Let me know if 1939 is the same as the 1940 DeLuxe. If so, I will post lots of E-brake photos showing it's assembly. Here's a start.
03-07-2021, 01:29 PM | #3 | |
Re: Parking brake
[email protected] |
03-07-2021, 01:30 PM | #4 |
Re: Parking brake
Sounds like the hand brake paw spring has broken. 91A-2788
03-07-2021, 01:33 PM | #5 |
Re: Parking brake
Sounds like 91A-2788 hand brake paw spring is broken.
03-07-2021, 01:51 PM | #6 |
Re: Parking brake
Mart. |
03-07-2021, 04:38 PM | #7 |
Re: Parking brake
I can't see where that spring goes on my 40. Is it hidden inside?
Does it actuate the metal "pawl" shown in 2nd photo? I have the feeling that the small clevis pin with the small cotter pin goes thru that spring and that it rides on that pin. |
03-10-2021, 11:02 AM | #8 |
Re: Parking brake
If the picture loads the pin/bolt that mounts the pawl goes through the spring inside the parking brake. The short end of the spring goes against the pawl the long end goes to a "tab" cut out of the parking brake "mount".
03-07-2021, 06:55 PM | #9 |
Re: Parking brake
Thanks for all the replies. Those of you who said pawl spring are correct. Now to make the repair.
03-07-2021, 07:17 PM | #10 |
Re: Parking brake
Take photos as you disassemble and before things fly apart.
03-08-2021, 11:19 AM | #11 |
Re: Parking brake
It is quite common for that spring to be broken. I made a spring out of spring wire and some heat. Not a great solution, nothing like the original. Who makes them? Good Luck: Fred A
03-10-2021, 09:50 AM | #12 |
Re: Parking brake
Macs has them probably others. A well stocked local hardware probably hS something that would work with some creative bending. Easier if you have some of the old spring to match though
03-10-2021, 12:06 PM | #13 |
Re: Parking brake
Bill, thanks for posting that photo.
